CM3+ Released with up to 32GB eMMC
Mon Jan 28, 2019 10:12 am
https://www.raspberrypi.org/blog/comput ... w-from-25/
Compute Module 3+ is, like Raspberry Pi 3B+, the last in a line of 40nm-based Raspberry Pi products. We feel that it’s a fitting end to the line......
Retired disgracefully.....
gordon77
Re: CM3+ Released with up to 32GB eMMC
Mon Jan 28, 2019 2:13 pm
This must be the quietest launch of a Pi product to date. Only 2 comments on the blog !!
Mon Jan 28, 2019 2:41 pm
Yup. Weird.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
W. H. Heydt
Mon Jan 28, 2019 3:13 pm
I'm not exactly surprised. I suspect that most people that use the CMs aren't heavy blog readers, and the blog readers that don't usually use CMs probably wouldn't have much to say about it.
I was amused by the one comment asking if the CM3+ board have 1GB or 2GB RAM, which indicates that he is unaware of the VC4 memory limitation.
W. H. Heydt
Mon Jan 28, 2019 3:15 pm
Interesting indeed. I'll have to run some tests with the CM3L+. One must also surmise that the NEC CM3-16 has sold well (despite the price) and led to the larger eMMC models. Kudos to the RPT for bringing them in at a pretty low price, all things considered.
Mon Jan 28, 2019 3:19 pm
It will be interesting to see if NEC lowers the price point and offers the CM3+ !
burtyb
Mon Jan 28, 2019 6:01 pm
Probably confused by the comparison of the new CM3+ with the original CM and not the CM3 but I imagine saying "It has the newer BCM2837B0 but runs at the same speed and has the same amount of RAM but it does have bigger and more options for flash storage" doesn't sound as good.
hippy
Mon Jan 28, 2019 7:10 pm
Any details of the revision number for the CM3+ ?
I'm guessing a020f0 or a220f0 depending if manufactured by Sony or Embest.
https://www.raspberrypi.org/documentati ... /README.md
PhilE
Mon Jan 28, 2019 7:16 pm
From memory, it's a02100.
hippy
Mon Jan 28, 2019 7:19 pm
Ooh. I hope so because that suggests there's a new "0xF" product sitting between the 3A+ and CM3+ :P
DarkPlatinum
Contact: Website YouTube
Mon Jan 28, 2019 7:48 pm
Did not know about this until reading this post. Maybe I should post this on my website so that more people know about it?
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
W. H. Heydt
Mon Jan 28, 2019 8:47 pm
There's a blog post--up today (28 Jan 2019)--on the front page of this very web site...
W. H. Heydt
Mon Jan 28, 2019 8:48 pm
That would--logically--be the one board that hasn't been bumped to the BCM2837B0 yet, to wit, a Pi2Bv1.3 (which would amount to a Pi3B+ without WiFi).
W. H. Heydt
Tue Jan 29, 2019 12:35 am
Or if they just drop their own orders and point people to the 16GB or 32GB(!!) CM3+ boards.
Also...notice what *isn't* there. There is *no* 4GB version.
PeterO
Tue Jan 29, 2019 6:57 am
https://twitter.com/Raspberry_Pi/status ... 0255430658
So that's at least 400,000 other people that know about it :lol:
PeterO
DarkPlatinum
Tue Jan 29, 2019 9:00 am
PeterO
Unfortunately, I don't have twitter. I read the Raspberry Pi Blog from time to time but haven't looked at it recently.
Tue Jan 29, 2019 10:00 am
Been a fairly low key launch, as the majority of Pi users are not particularly interested in the CM as its aimed towards industry. The people who need to know it's there know it's there!
W. H. Heydt
Tue Jan 29, 2019 2:46 pm
PeterO
You can read twitter without having an account. I do so in the occasional special circumstance.
aBUGSworstnightmare
Tue Jan 29, 2019 4:14 pm
Yes, they did!
Been away for BT to Japan and just found the blog/threat.
That's exactly what I was hoping to see! So thanks to the foundation for the new CM3+.
Now need to check where I can source them fast...
nixy82
Wed Jan 30, 2019 8:59 am
Hi
Nice news, well done guys
Does the new CM3+ require any changes to the dtblob.bin setup file?
i.e. Will it key off the pins_cm3 section still or will it be looking for pins_cm3plus ?
Which OS and kernel/firmware revision is the minimum that will support the new Chip?
Andrew
Wed Jan 30, 2019 10:07 am
Hi
Andrew
Latest kernel and firmware is almost always needed when new products come out, but will get someone to check. Not sure about dtblob, will flag it up also.
PhilE
Wed Jan 30, 2019 10:20 am
Any firmware from the November Raspbian release (and a bit before) is fine. Apart from the revision code, as far as software is concerned it should be treated like a CM3, i.e. same dt-blob section, same .dtb etc.
nixy82
Wed Jan 30, 2019 10:44 am
Great!
Are there any changes required to the rpi-boot flashing assistant, having some problems getting a drive letter up to start flashing it
Is it me being all fingers and thumbs or ...?
Edit: Yes I just needed to update the rpi-boot program to the latest version from github and we're back in business
PhilE
Wed Jan 30, 2019 10:45 am
No changes are required that I am aware of.
Gavinmc42
Wed Jan 30, 2019 11:05 am
This one actually makes me think of acquiring a few.
Pi tablet/notebook?
They have tended to be a bit pricey.
WiFi less Pi2B+? Purely for net connected stuff?
End of the line?
That means the new Pi's will be stronger, faster, cheaper :lol:
So the engineers have no distractions now, full steam ahead with Pi4, 5, 6?
FPGA's can be got for about $1 now, hint :lol:
I'm dancing on Rainbows.
Return to “Compute Module”
