oweno
Disabling Activity LED (after enabling it)
Sun Dec 02, 2018 12:39 pm
In our application we have a status LED connected to GPIO 24 and configured as the activity led :
    dtoverlay=pi3-act-led,gpio=24,activelow=on
This works great, but is there a way to disable activity led on this pin after boot up? Essentially I want to alert the user of activity during boot up, then once it is up, use the LED for another status purpose.
PhilE
Re: Disabling Activity LED (after enabling it)
Sun Dec 02, 2018 4:36 pm
This might be simple, or it could be tricky. The potential issue is that, although it is easy to stop the LED from flickering, I think the LED driver will not release its claim on the GPIO, which could interfere with your subsequent usage.
You can turn off the LED activity with:
$ echo none > /sys/class/leds/led0/trigger
Then try your application and see if contention is going to be a problem.
oweno
Mon Dec 03, 2018 2:41 am
Thanks for this! It seems to work fine after a quick check.
Return to “Compute Module”
