USB Type C: Do I need to do anything different for USB_OTG?
Posted: Tue Nov 06, 2018 4:04 pm
by InsertTitle
Question has been probably asked before but just want to check for my sake.
Currently replacing the USB Micro AB receptacle connector on my carrier board (Houses my CM3) for a USB Type C connector, do I need to change anything for USB_OTG to work on the new connector?
I know that on USB micro I had to get myself a AB connector instead of a A or B connector. So should I be looking for a USB Type C connector that has AB connector or does it just come built in and so I should just add any random Type C connector?
Also according to datasheets I can't seem to find an ID pin on the Type C connector, I noticed online that apparently CC1 & CC2 take on the form of the ID pin however it shows that they need to be pulled up with a 5K Resistor.
My only confusion with this is I want to use both Host and Slave modes. So how would I get around this? Cause I obviously don't want to plug into wall socket and it starts trying to activate OTG mode when I clearly want it to be charging and vice versa plugging into a computer and it not activating OTG mode.
Re: USB Type C: Do I need to do anything different for USB_OTG?
Posted: Wed Nov 07, 2018 8:20 pm
by aBUGSworstnightmare
First hit on Google https://ashleyslab.co/usb-type-c-mod-time/
And some more here https://electronics.stackexchange.com/q ... b-a-pinout
Sorry,don't have a link to the spec atm as this would be the reference for me
Posted: Mon Nov 26, 2018 12:45 pm
by InsertTitle
Ended up doing myself, but I think I've got it right will find out when comes assembly.
I connected both cc pins together and connected them to the USB_OTGID pin on the compute module, then just followed simple route of connecting Vbus together and GND together. I had no need for D+ / D- as far as I'm aware.so left those alone. if I'm incorrect then oh well. but I can simply change board design and send off for another board.
Posted: Thu Apr 11, 2019 3:31 am
by javaraspi
Did your design worked?
Best regards
