mattwenger
ssh over usb to a Compute Module 3
Sat Feb 10, 2018 11:29 pm
Is it possible to ssh over usb to a Compute Module 3 using the Compute Module IO Board V3 in a similar way to how it is done on a Pi Zero?
Here is information on how it can be done on a Pi Zero - https://www.thepolyglotdeveloper.com/20 ... cable-ssh/.
I'm using Raspbian Stretch Lite (Nov. 2017 release). I followed the information given for connecting to the Pi Zero, but add dtoverlay=dwc2 to the config.txt file causes an error while booting (it scrolls too fast to see), and also prevents me from logging in directly to the Pi.
gsh
Re: ssh over usb to a Compute Module 3
Sun Feb 11, 2018 3:38 pm
If you use the dwc2 driver, it supports both device and host modes, but uses the OTG_ID pin to decide on which mode to choose, we currently have a pull down on the OTG_ID pin to default it to host mode...
What you'll need to do is to force it into peripheral mode using dtoverlay=dwc2,dr_mode=peripheral
That will then set it up as a peripheral...
Think that's likely to be your problem
Gordon Hollingworth PhD
mattwenger
Mon Mar 05, 2018 6:02 pm
Thanks gsh, I will give that a try.
munixnet
Sat Oct 27, 2018 1:34 am
Were you ever able to get it running? I'm currently having the same issue, I did what you suggested with the ID and am still not able to get it to detect on my windows machine. I have a computer module 3 and am running Rasbian Stretch lite, October 2018.
gsh
Sun Oct 28, 2018 6:09 am
So you're still getting the error message in dmesg at bootup? Can you paste the relevant bit of the message
Gordon
kajaldesai
Wed Jan 09, 2019 6:13 am
Hello
I am using raspberry pi compute module 3 and i/o board. i wanted to login in cm3 module like raspberry pi zero. so I add dtoverlay=dwc2,dr_mode=peripheral in config.txt file and modules-load=dwc2,g_ether in cmdline.txt file. In this case i am able to login like pi zero using raspberrypi.local but when I remove above command from config.txt and cmdline.txt file, my mouse and keyboard are not working.
Return to “Compute Module”
