CM3L SD Card
Posted: Thu Apr 27, 2017 1:50 pm
by inches
With the CM3L I started using GPIO22-27 to connect to SC cards but then I realized those are SDO ALT1 pins.
Am I correct in guessing that SDX_CLK/CMD/DAT0-3 are what I route to my SD Card?
Are the SDX pins the default pins to connect to SD cards in the device tree?
Do I need any pullups?
Re: CM3L SD Card
Posted: Thu Apr 27, 2017 2:33 pm
by aBUGSworstnightmare
Please allow me to reset you to the Compute Module IOBoard schematics
https://www.raspberrypi.org/documentati ... EMATIC.pdf
And the Compute Module documentation
https://www.raspberrypi.org/documentati ... tasheet.md
They will ansewer your question.
And yes, SDX-pins are 'default' (in regards of standard device tree) pins for SDcard interface.
