[Question] Perimeter
Posted: Mon May 21, 2018 5:51 pm
by 456mb
Hi !
i start a proyect in the university but i have a big question (sry my language native no is english), i want check via GPS if the prototype is inside of the irregular area, image of example
i dont have problem with sensor, the big big dude is, how check is inside of the irregular perimeter, some idea for start ?
any idea is welcome
thanks for you time
Re: [Question] Perimeter
Posted: Mon May 21, 2018 6:20 pm
by HawaiianPi
That depends on how the perimeter is defined. For example, painted lines could be detected with a camera. If the perimeter is not clearly marked, then it becomes more difficult. GPS might work for an outdoor location, but might not work inside a building (or any location with poor GPS reception). We really need more information to help you.
Posted: Mon May 21, 2018 6:25 pm
by B.Goode
any idea is welcome
Go to the Mathematics Department of your University and ask them to teach you some (Cartesian) coordinate geometry.
It is an interesting question.
But it is not one that is directly related to the use of a Raspberry Pi.
Posted: Mon May 21, 2018 7:56 pm
by 456mb
yes, that use in open field, the points will be configured previusly (point = GPS position)
The general idea is use in a motorbike for big places, but the first step is detect the area
Posted: Mon May 21, 2018 8:31 pm
by drgeoff
Surely anyone in a University faculty doing this project would have already been taught coordinate geometry at school.
Posted: Mon May 21, 2018 9:06 pm
by 456mb
it's irony ?
its a free proyect, the question how to pass the points to identify them as a "side"
Posted: Tue May 22, 2018 7:49 pm
by ejolson
Maybe even Calculus, but apparently not on this forum. Does Green's theorem help?
Posted: Tue May 22, 2018 8:55 pm
by B.Goode
Presumably you will represent the points defining the area as pairs of coordinates in the form returned by a GPS receiver. The standard used to be WGS84, but that may no longer be current.
I think I remember that if you know the coordinates of 2 points in a plane you can deduce the equation for the straight line passing through those points? The portion of that line between the 2 positions represents a side of your boundary shape.
(Still not sure why this is in a Raspberry Pi forum.)
Posted: Tue May 22, 2018 10:13 pm
by ejolson
I think the idea is to build a GPS surveying tool using Raspberry Pi. Green's theorem is surely the way to compute the area. Please read the whole Wikipedia article I linked to in my previous post.
Posted: Tue May 22, 2018 10:54 pm
by gkaiseril
One might also want to look at the Coastline paradox. It might not be as simple as some think.
Posted: Wed May 23, 2018 2:28 am
by ejolson
Interesting article. While the length of the coastline may not be well defined, the area enclosed is. But now that I reread the question I see that it isn't a matter of finding the area, but whether a particular point is inside or outside the area. Again the answer can be determined by an integral over the perimeter, just a different one than for finding area.
Posted: Wed May 23, 2018 8:43 am
by scotty101
The information at this link seems helpful
http://alienryderflex.com/polygon/
Posted: Sat May 26, 2018 5:09 am
by 456mb
thank all the guys for taking the time to help me find a solution :D
I want to thank you, I turned google looking for information but I did not succeed
It's just what I needed to put the idea, I want to tell you that this was the last problem for my project to work.
Really thank you ;)
Posted: Sat Jun 02, 2018 2:04 am
by Heater
There is a much simpler way to find if a point is inside or outside a polygon. Use the "winding number algorithm" See here: https://en.wikipedia.org/wiki/Point_in_polygon
