Page 2 of 2
Re: Mathematica start-up crashing RDP session
Posted: Thu Mar 24, 2016 12:57 pm
by drupol
I've installed Raspbian from the .img file using the dd command in Linux and I have the same file.
pi@rpi8gb:~ $ cat /usr/share/raspi-ui-overrides/applications/wolfram-mathematica.desktop [Desktop Entry]
Encoding=UTF-8
Type=Application
Version=1.0
Name=Mathematica
Comment=Technical Computing System
Icon=wolfram-mathematica
Exec=mathematica %F
TryExec=mathematica
Terminal=False
MimeType=application/mathematica;application/vnd.wolfram.cdf;application/mathematicaplayer
Categories=Application;Development;
StartupNotify=true
pi@rpi8gb:~ $
Posted: Thu Mar 24, 2016 3:37 pm
by dgordon42
OK, its most odd that Mathematica won't work for you.
I'm away from base now until Monday, so no Pi, but I'll have another think about it then.
There don't seen to be any reports of this in the Wolfram forums either
Dave.
Posted: Thu Mar 24, 2016 3:42 pm
by drupol
dgordon42 wrote:OK, its most odd that Mathematica won't work for you.
Dave.
Let things be clear: Mathematice works if i connect the Pi to my TV (hdmi) and when I use a keyboard and a mouse connected to it.
But I would like to work "remotely" with Mathematica. This is why I'm using XRDP. Easy, fast and well integrated in Linux.
And it's only when using XRDP that it crashes.
I will try to make a video tomorrow, I'll post it here.
Posted: Sat Mar 26, 2016 10:25 am
by jpsa
I've reinstalled wolfram-engine, just in case, and it made no difference.
I've reconnected my pi3 to a screen & mouse, and Mathematica works fine, as before, if I use those. Remote desktop in to the same machine and it still crashes out during Mathematica startup.
Right-click>About on the window banner of the Windows remote desktop client connection screen says
Is that the version you are using on your Windows 10 machine?
Posted: Sat Mar 26, 2016 11:08 am
by jpsa
Some more information which may or may not be relevant... if I give the following command
LIBGL_DEBUG=verbose mathematica >m.txt 2>&1
from the real screen & keyboard, nothing is written to the m.txt log file. If, however, I give it from the remote desktop I get
libGL: OpenDriver: trying /usr/lib/arm-linux-gnueabihf/dri/tls/swrast_dri.so
libGL: OpenDriver: trying /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so
libGL: Can't open configuration file /home/pi/.drirc: No such file or directory.
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
The file /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so does exist on my machine, though (Googling suggests it's part of the libgl1-mesa-dri package, which is already installed). I have no idea what the rest of the messages might signify!
Posted: Thu Mar 31, 2016 6:34 am
by Gerd
Based on jpsa's findings above I placed a file .drirc in /home/pi with content
<driconf>
</driconf>
That eliminated the "Can't open file" errors in the libGL log.
Additionally calling mathematica as root
LIBGL_DEBUG=verbose sudo mathematica >m.txt 2>&1
also eliminated the first 2 lines from the log as I now only get in m.txt
but Mathematica still crashes over XRDP.
This is how far I got. But I am clueless how to proceed. Does this mean we have a driver access problem? Which config needs to be in /home/pi/.drirc ?
Edit:
This is not only Mathematica related.
After installing the mesa-utils package with
sudo apt-get install mesa-utils
running the demo glxgears with
glxgears
it shows the same behaviour: Running fine when attached to Screen, KB, Mouse; over XRDP crash with the same errors.
When launching with
LIBGL_DEBUG=verbose glxgears >g.txt 2>&1
I get the following in g.txt
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":11.0"
      after 160 requests (37 known processed) with 0 events remaining.
Posted: Tue Apr 05, 2016 7:15 pm
by drupol
Still no solution ?
Posted: Wed Apr 06, 2016 1:17 am
by shkng
removed xrdp, installed vnc4server instead --
https://linuxconfig.org/quick-vnc-serve ... x-jessie-8
same problem - as mathematica starts the connection aborts
Posted: Tue Apr 12, 2016 9:09 am
by Gerd
No update with the original problem, but I can report a working alternative.
Just install tightvnc (together with autocutsel if you want clipboard exchange) and use your prefered VNC viewer on the client side. On Windows I use the portable Version of MobaXterm because it also contains SSH, SFTP, X11 Server etc.
With tightvnc I had none of the GDBus Errors that were mentioned earlier in this thread.
The performance of thightvnc is quite good. Rotate a 3DPlot with the mouse and you will see!
Posted: Thu Apr 14, 2016 10:16 pm
by shkng
Thank you. Uninstalled vnc4server, installed tightvncserver, works!!
Posted: Thu Apr 14, 2016 11:29 pm
by shkng
some observations:
1. see tightvnc docs to set password, and start tightvncserver before it allows connection
2. tightvnc default settings don't seem to have a US-keyboard, so Ctrl-Enter (to evaluate) does something weird -- but definitely works because menu "Evaluate" works fine
3. just tried xrdp on a whim, now that works ! suspect something in vnc4server that was removed and when tightvnc was installed it allows xrdp to work ..
Posted: Thu Apr 14, 2016 11:52 pm
by shkng
silly me - evaluate is Shift-Enter, which works fine.
so tightvnc is fine too, probably more lightweight if you don't want the full desktop.
