tinylcd
3.5 Inch TFT Display for Raspberry Pi
Mon Jun 09, 2014 7:47 am
3.5 inch TFT/lcd/display having 320x480 pixels for raspberry pi with touch screen and/or navigation keys and various other combinations
Ready to use TinyLCD products 3.5 inch display now available on following website
http://www.neosecsolutions.com//index.p ... 6364429766
We thank notro for developing the frame buffer for it
All these lcds will be branded under TINYLCD
The navigation keys use CAPACITIVE technology
Various options are available to meet your budget and need as follows:
Display only
Display only
Display with touch panel
Display with navigation key
All above three options are available with RTC and without RTC
By default images are provided on DVD for above options
Optionally one can by sd card with images preloaded for above options
refer below link to interface 3.5 inch TFT (tinylcd35) on pi
https://github.com/notro/fbtft/wiki/LCD-Modules
https://github.com/notro/rpi-firmware
Regards
neosecsolutions
DRAgon715205
Re: 3.5 Inch TFT Display for Raspberry Pi
Tue Jul 01, 2014 10:00 am
How the LCD install the driver, have a user guide??
tinylcd
Thu Jul 03, 2014 5:00 am
Hello
there is no need to install any driver for this TFT
notro has developed the frame buffer for this tft
we supply you DVD for the OS
or optionally you can buy the sd card from us with OS loaded
tinylcd
stevejferry
Sat Jul 12, 2014 4:20 pm
Hi, I have installed the OS from CD and display works in text mode but when I change boot options so the Pi starts in Graphics mode, it hangs. Your photos show Pi running LXDE, please help, I need to use Qt to develop graphical output on this display.
Thanks, Steve
OK, since posting this, I have found that although it hangs if I try to get it to boot to LXDE, but if I type startx at the prompt after logging in, LXDE runs OK .....
There are 10 types of people. Those who understand binary and those who don't.
tinylcd
Mon Jul 14, 2014 5:51 am
TFT framebuffer Driver are built in to the special kernel itself as the frame buffer drivers need kernel mode operations
the fbtft drivers need dma spi for speed , which is not available in standard OS (wheezy) .
for QT please reffer QT docs for integrating any standard frame buffer drivers.
or please check the x windows config files for more info regarding the frame buffer settings
you may need to add new compiled kernel by patching the existing kernel with fbtft changes
also the kernel is based on standard OS (wheezy),
should not be any issue in adding your customised changes to it as you do for standard OS .
Please refer fbtft source code and wiki for further info.
FBTFT
Linux Framebuffer drivers for small TFT LCD display modules.
The module 'fbtft' makes writing drivers for some of these displays very easy.
Development is done on a Raspberry Pi running the Raspbian "wheezy" distribution.
INSTALLATION
Download kernel sources
cd drivers/video
git clone https://github.com/notro/fbtft.git
Add to drivers/video/Kconfig: source "drivers/video/fbtft/Kconfig"
Add to drivers/video/Makefile: obj-y += fbtft/
Enable driver(s) in menuconfig and build the kernel
See wiki for more information: https://github.com/notro/fbtft/wiki
Source: https://github.com/notro/fbtft/
tinylcd
stevejferry
Tue Jul 15, 2014 7:34 am
The Pi boots with the LCD as default, the output to the HDMI gets switched off.
Once the Pi has booted, is it possible to switch between HDMI and LCD output?
Steve.
notro
Tue Jul 15, 2014 8:44 am
Have a look at this: https://github.com/notro/fbtft-spindle/ ... -multiseat
I'm on holiday without a Pi, so if you get stuck I can't help you.
stevejferry
Sat Aug 09, 2014 11:08 am
I'm using one of these screens which came with an input pad and an RTC but as I don't want the input pad, I have disconnected it. I'm using the OS which came on a CD with the screen.
Can anyone tell me how to disable the gpio_mouse_device driver - I have an ADC I am bitbanging on GPIO 14, 15, 17 & 27 and it is interfering with the mouse. Everytime I move the mouse pointer with my USB mouse, the pointer just heads on back to the top left corner as the GPIO mouse driver uses GPIO17 and 27 for up and left.
I have tried commenting out the following line in the /etc/modules file but to no avail.
#gpio_mouse_device pulldown polarity=0 up=17 down=22 left=27 right=23 bleft=4
Any advice to get round this problem (other than use alternative GPIO pins for my ADC) would be very helpful.
Regards
Steve.
iwanodank
Wed Aug 13, 2014 4:05 am
Dear..
i am realy confuse how to install the driver.
i buy the lcd from neosecsolutions.com, and i got the dvd for the OS.
but, i need to use my previous OS so i just have to install the driver.
cd drivers/video --> which directory in my raspbian?
Add to drivers/video/Kconfig: source "drivers/video/fbtft/Kconfig" --> what mean of "Add"
Add to drivers/video/Makefile: obj-y += fbtft/ --> what mean of "Add"
i am newbie on raspberry
tinylcd
Thu Aug 14, 2014 4:28 am
Hello Iwam
links to generic FBTFT pre-built OS images is available on the internet at notro git site .
https://github.com/notro/fbtft/wiki#image-download
The above images are GENERIC FBTFT KERNEL ONLY
Users need to configure it for various different TFT Displays devices by following the wiki and forums
Advised tft user to get familiar in updating RPi's the firmware to norto special kernel for FBTFT support .
source code https://github.com/notro/fbtft
wiki and self help https://github.com/notro/fbtft/wiki
https://github.com/notro/fbtft/wiki#ste ... sing-fbtft
regards
tinylcd
tinylcd
Thu Aug 14, 2014 4:30 am
Hello steve
hope your problem is solved by the image already provided to you on the DCD
regards
tinylcd
iwanodank
Thu Aug 14, 2014 10:05 am
Dear tinylcd
Thank you, now i can use the LCD. it's very good display.
Iwan
stevejferry
Fri Aug 15, 2014 8:34 am
Thanks TinyLCD, yes I was using wrong image. All good now.
PRASHANT SHARMA
Thu Nov 20, 2014 8:23 am
i bought a tinylcd 3.5" touchscreen and want to use it on my raspberry pi B model. DVD you given have image of almost 8gb(35TFT_TS_B+_16092014) it will work on only B+ model? i write it on sd card then boot my raspberry pi but nothing happen. there is only red and dim green light glowing and nothing boot. so how can i interface my lcd to pi board??
BMS Doug
Thu Nov 20, 2014 8:36 am
PRASHANT SHARMA wrote:i bought a tinylcd 3.5" touchscreen and want to use it on my raspberry pi B model. DVD you given have image of almost 8gb(35TFT_TS_B+_16092014) it will work on only B+ model? i write it on sd card then boot my raspberry pi but nothing happen. there is only red and dim green light glowing and nothing boot. so how can i interface my lcd to pi board??
An image that will work on a B+ will also work on an A or a B (and most likely on an A+). I suspect that you have incorrectly written the image to the card.
I would recommend that you reformat the card and try again.
Doug.
PRASHANT SHARMA
Thu Nov 20, 2014 9:21 am
thanks for reply
1. i used SDFormatter for format.
2. i write the image using win32diskmanager.
is it wrong?
Thu Nov 20, 2014 9:57 am
Has the image file that you've got been unzipped (are you sure it's not compressed)? Is your SDCard big enough?
This is a doctor free zone.
Scottyc
Thu Feb 05, 2015 9:17 am
If you want to install the LCDs on a clean version of Raspbian or Rasbmc, I have written up a tutorial with a beginner in mind on how to do it. It took several days of research to find out exactly how to install the drivers and get the touchscreen configured and calibrated correctly, but I have it working nicely. If you want to save some time and headaches, check out the article here: http://www.circuitbasics.com/setup-lcd- ... pberry-pi/
Circuit Basics blog - Arduino, Raspberry Pi, and DIY Electronics Projects, Articles, and Tutorials... http://www.circuitbasics.com
jehamann
Contact: AOL
Mon Feb 23, 2015 8:05 am
[/img]@tinylcd I bought your $25 3.5 tft. I used the 35TFT_B+_03092014.img provided and I am having problems with it. I go to set up my wifi and part of the program gets cut off, so now I cant install the recommended stuff.
AndyD
Mon Feb 23, 2015 9:14 am
jehamann wrote:@tinylcd I bought your $25 3.5 tft. I used the 35TFT_B+_03092014.img provided and I am having problems with it. I go to set up my wifi and part of the program gets cut off, so now I cant install the recommended stuff.
It's not really Neosec/Tinylcd's problem. Simply the dialog box doesn't fit on the display. However, try using a different wifi configuration program. You can run wicd-curses from a terminal. You will need to install it first.
sudo apt-get update
sudo apt-get install wicd-curses
sudo wicd-curses
This guide appears to run through the procedure for setting up wifi using wicd-curses. It is a little old, but is probably still correct.
ragnarjensen
Mon Feb 23, 2015 11:54 am
Many window managers allow moving windows by clicking anywhere in the window while holding down the Alt key.
Ragnar
jehamann
Contact: AOL
Mon Feb 23, 2015 3:58 pm
Thanks for the replies!!!! it might not be, but I was under the assumption everything was more plug and play/ and it is to a point (my bad) but what about other programs? im also using an A+ so no Ethernet. @ragnarjensen ill have to try that but I dont shouldn't have to resize every window on every program I run.
ragnarjensen
Sat Feb 28, 2015 1:52 pm
jehamann wrote: @ragnarjensen ill have to try that but I dont shouldn't have to resize every window on every program I run.
It's not for resizing the window, it's for moving it. Instead of clicking on the title bar and dragging, Alt-click anywhere in the window and drag. Thus, you can drag a window upwards, even if the title bar already is at the top of the display.
Ragnar
jehamann
Contact: AOL
Thu Mar 19, 2015 2:57 am
Ok, so its been awhile but I was finally able to try it, it moves the tab around and I was to get to the buttons I needed for the wifi, but I mean there just has to be a way to go in and resize the gui so that the background and the programs open up for the correct size of the screen.
giorgiofolle
Mon Mar 23, 2015 6:21 pm
Hi !
If i would install Debian 8 in my rpi , is the Debian 8's kernel compatible ?
Return to “For sale”
