Page 2 of 2
Re: The Pi Co-op - an Arduino Add-on Board for the Raspberry
Posted: Sat May 17, 2014 12:26 am
by QBall1977
Any chance you can help. I'm an Arduino newbie. But basically I followed another tutorial to hack some IKEA DIODER Lights, you remove the controller, wire to Red, Green, Blue, a common ground and common +5v. The following .ino works when uploaded via the Arduino IDE... :P
// color swirl! connect an RGB LED to the PWM pins as indicated
// in the #defines
// public domain, enjoy!
#define REDPIN 5
#define GREENPIN 6
#define BLUEPIN 3
#define FADESPEED 5 // make this higher to slow down
void setup() {
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
void loop() {
int r, g, b;
// fade from blue to violet
for (r = 0; r < 256; r++) {
analogWrite(REDPIN, r);
delay(FADESPEED);
// fade from violet to red
for (b = 255; b > 0; b--) {
analogWrite(BLUEPIN, b);
delay(FADESPEED);
// fade from red to yellow
for (g = 0; g < 256; g++) {
analogWrite(GREENPIN, g);
delay(FADESPEED);
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
I was hoping to have similar control over the LEDs using the PyMata, however I'm having trouble finding an example that uses PWM and allows analog writes. :?
I thought something like this would work but it seems to output nothing. Do you have any suggestions?
import time
from PyMata.pymata import PyMata
# Give the pins names:
REDPIN = 5
GREENPIN = 6
BLUEPIN = 3
FADESPEED = 5
# Create an instance of PyMata.
SERIAL_PORT = "/dev/ttyS0"
firmata = PyMata( SERIAL_PORT, max_wait_time=5 )
# initialize the digital pin as an output.
#firmata.set_pin_mode( LED, firmata.OUTPUT, firmata.DIGITAL )
firmata.set_pin_mode( REDPIN, firmata.OUTPUT, firmata.PWM)
firmata.set_pin_mode( GREENPIN, firmata.OUTPUT, firmata.PWM)
firmata.set_pin_mode( BLUEPIN, firmata.OUTPUT, firmata.PWM)
try:
# run in a loop over and over again forever:
while True:
#for r in range (0,256,1):
firmata.analog_write( REDPIN, 255 )
firmata.analog_write( GREENPIN, 0 )
firmata.analog_write( BLUEPIN, 255 )
time.sleep(1.0) # wait for a second
except KeyboardInterrupt:
# Catch exception raised by using Ctrl+C to quit
pass
# close the interface down cleanly
firmata.close()
Sorry, should have posted it like this in the first place. Apologies.
Mark.
Posted: Sat May 17, 2014 12:45 pm
by abroun
Hi there,
If you're still having a problem with this then I think that you're almost there, you should just need to set the pins to ANALOG rather than PWM. So the following should hopefully work (no Pi Co-op or Arduino on hand to test this at the moment)
# initialize the pins as analog output.
firmata.set_pin_mode( REDPIN, firmata.OUTPUT, firmata.ANALOG )
firmata.set_pin_mode( GREENPIN, firmata.OUTPUT, firmata.ANALOG )
firmata.set_pin_mode( BLUEPIN, firmata.OUTPUT, firmata.ANALOG )
The documentation for PyMata is a bit sparse, but if you scroll down you should see a bit more detail on using set_pin_mode.
Hope that helps.
Regards
Alan
Posted: Sat May 17, 2014 10:54 pm
by QBall1977
Alan,
Thanks for the swift response, I appreciate you taking the time. I tried what you suggested however I get the following error. I thought I had issues with the pin numbers, should these be the same as stated on the Pi CO-OP board? (they're the PWM3, PWM5, PWM6 pins)
Here's the error.
Opening Arduino Serial port /dev/ttyS0
Please wait while Arduino is being detected. This can take up to 5 seconds ...
Board initialized in 0 seconds
Total Number of Pins Detected = 20
Total Number of Analog Pins Detected = 6
  File "MRO_DIODER.py", line 18, in <module>
    firmata.set_pin_mode( GREENPIN, firmata.OUTPUT, firmata.ANALOG)
  File "/home/pi/PyMata/PyMata/pymata.py", line 718, in set_pin_mode
    self._command_handler.analog_response_table[pin][self._command_handler.RESPONSE_TABLE_MODE] = mode
IndexError: list index out of range
Exception in thread Thread-1 (most likely raised during interpreter shutdown):Exception in thread Thread-2 (most likely raised during interpreter shutdown):
Traceback (most recent call last):Traceback (most recent call last):
  File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
  File "/home/pi/PyMata/PyMata/pymata_serial.py", line 106, in run
  File "/home/pi/PyMata/PyMata/pymata_command_handler.py", line 698, in run
  File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 432, in inWaiting
<type 'exceptions.TypeError'>: 'NoneType' object is not callable
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'unpack'
I wish I was more familiar with arduinos, perhaps the pins should be referred to differently when using PyMata?
Any further suggestions?
Thanks in advance.
Mark.
Posted: Sat May 17, 2014 11:39 pm
by QBall1977
A bit of additional information, this error seems to be when setting PIN 6. So I commented this out. The remaining code still does nothing. :? I can't see why the original INO file works and this does not.
import time
REDPIN = 5
GREENPIN = 6
BLUEPIN = 3
FADESPEED = 5
firmata.set_pin_mode( REDPIN, firmata.OUTPUT, firmata.ANALOG)
#firmata.set_pin_mode( GREENPIN, firmata.OUTPUT, firmata.ANALOG)
#firmata.set_pin_mode( BLUEPIN, firmata.OUTPUT, firmata.PWM)
try:
    while True:
#       firmata.analog_write( GREENPIN, 255 )
#       firmata.analog_write( BLUEPIN, 255 )
    pass
firmata.close()
Posted: Mon May 19, 2014 2:51 pm
by abroun
Hi there,
First of all, apologies that my first reply didn't work. I think the key lesson here is not to offer advice without having the hardware to test it. :oops:
Now reading through the PyMata and Firmata source code a bit more carefully, it looks like the lines you actually want here are
# initialize the pins as analog PWM.
firmata.set_pin_mode( REDPIN, firmata.PWM, firmata.DIGITAL )
firmata.set_pin_mode( GREENPIN, firmata.PWM, firmata.DIGITAL )
firmata.set_pin_mode( BLUEPIN, firmata.PWM, firmata.DIGITAL )
I have tested this with pins 3, 5, and 6 and they all seem to produce the correct PWM signals when you use analog_write. I think that the main problem here is that that particular PyMata routine isn't that clear, or well documented. The DIGITAL/ANALOG setting only seems to have an effect when the pins are used as inputs, or as digital outputs...
Hope that helps.
Regards
Alan
Posted: Mon May 19, 2014 6:45 pm
by QBall1977
Alan,
Thanks for your response, that worked a treat! I can also confirm that Nanpy works with the Pi CO-OP. Despite some misleading documentation and few problems installing into python. That worked well too. (see example below, of course you have to download the Nanpy to the Arduino first!)
from nanpy import Arduino
from nanpy import SerialManager
from time import sleep
#serial_manager.connect('/dev/ttyS0')        # serial connection to Arduino
connection = SerialManager()
a = Arduino(connection=connection)
a.pinMode(5, a.OUTPUT)
a.pinMode(6, a.OUTPUT)
a.pinMode(3, a.OUTPUT)
RLED = 5                        # LED on Arduino Pin 10 (with PWM)
GLED = 6
BLED = 3
print"Starting"
print"5 blinks"
a.digitalWrite(BLED,a.LOW)
a.digitalWrite(GLED,a.LOW)
for i in range(0,5):
    Arduino.digitalWrite(RLED, Arduino.HIGH)
    sleep(0.5)
    Arduino.digitalWrite(RLED, Arduino.LOW)
    sleep(0.5)
print"Changing brightness of LED"
bright = 128                           # Mid brightness
a.analogWrite(RLED, bright)
#a.digitalWrite(LED,a.HIGH)          # Turn on LED
for i in range(0,200):
    bright = bright + 8
    if (bright > 200):          # LED already full on at this point
        bright = 0          # Minimum power to LED
    a.analogWrite(RLED, bright)           # Change PWM setting/brightness
    sleep(0.5)
a.digitalWrite(RLED,a.LOW)          # Turn off LED
print"Finished"
Posted: Mon Jul 07, 2014 8:44 am
by 64BR1
Hello!
I would like to control this co-op card with a program done in c++. Is there any library to do it? where can I find it?
Posted: Sat May 28, 2016 7:11 pm
by dhester
I know this is a bit old but does anyone have the tutorial as the site is down as Dawn has shut down.
