ApplePi DAC, Highest Performance Raspberry Pi DAC Launches
Posted: Sat May 05, 2018 3:22 pm
by orchardaudio
The ApplePi DAC went on a tour around the country. Here is what people who have tried it, have to say:
Wayne - Littleton, CO
"This is a very well engineered and built DAC. I again suggest folks sign up for the tour and listen yourself." and "I spent a good week listening to it and came away extremely impressed with what Leo has done with this DAC hat."
Alan - Harrisburg, OR
"I have had the Apple Pie for a while and I must say I am really impressed." and "Any way this is a dammed fine budget setup that punches way above it's weight."
Sharschchandra - Austin, TX
"The build quality is top notch and I really like the layout." and "The unit sound great out of box, very organic, almost neutral and full bodied (compared to ES9038PRO based DACs). The vocals were amazing especially on the JBL 4312B monitors."
Jerry - Camarillo, CA
"This is one sweet little Dac, Leo. I actually left work early today just to spend more time getting to listen." and "You have one helluva nice piece here; I appreciate the gracious demo."
The tour continues to this day, and will continue beyond Kickstarter. If you would like to sign up, go here: https://www.audiocircle.com/index.php?t ... msg1665901
Re: ApplePi DAC, Highest Performance Raspberry Pi DAC Launches
Posted: Tue May 08, 2018 7:39 pm
by orchardaudio
< 24 Hours Left
Posted: Sat May 12, 2018 10:36 pm
by orchardaudio
Less than 24 hours left.
Here is the full list 9f specs:
  • SNR: 128dB (A-Weighted)
  • THD+N: <0.0005% (-106dB)
  • Frequency Response: DC - 22kHz
  • Balanced Output Voltage: 5 Vrms (0dBFS)
  • Balanced Output Impedance: 200 ohms
  • Single Ended Output Voltage: 2.5 Vrms (0dBFS)
  • Single Ended Output Impedance: 100 ohms
  • Supported Sample Rates: 44.1, 48, 88.2, 96, 176.4 and 192kHz
  • Supported Bit Rates: 16-Bit and 24-Bit
  • Power Consumption: 4.5W (5V @ 0.9A)
  • Chipset: 2 × Burr Brown PCM1794A - monaural mode
  • Op Amps: 6 × OPA1612 - dual differential output configuration
https://www.kickstarter.com/projects/18 ... ry-pi-dac/
Posted: Mon Nov 19, 2018 9:48 pm
by orchardaudio
20% off all ApplePi products until Nov 30th. Get yours now:
https://orchardaudio.com/shop?olsPage=products
