jayer89
for those looking into solar power for the RPI
Tue Sep 11, 2012 8:09 pm
right now in maplin you can pick up a High-Power Folding solar charger for £5.99 it deos have a 1000mAh internal battery.
audigex
Re: for those looking into solar power for the RPI
Sat Sep 22, 2012 4:17 pm
Would this provide the constant power needed for a RPI though? Charging a battery in a phone is fine - lower current would just charge more slowly - but the RPI can't have voltage drops.
Does the battery provide a sufficient buffer zone for when the sun goes behind a cloud?
sotris99
Mon Sep 24, 2012 9:01 am
Ἓν οἶδα, ὅτι οὐδὲν οἶδα. (All I know is that I know nothing)
rew
Wed Sep 26, 2012 6:40 pm
In theory:
Output current: 800mA
should be enough.
I have tested two 1000mA adapters, one delivers what it claims, the other doesn't (and doesn't power a 'pi).
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
Johnny002
Mon Oct 29, 2012 5:33 pm
Technically, the way this works is that the solar energy taken in is used to charge a battery and the battery outputs the energy in a constant form to the RPi. Fluctuation in input are irrelevant and if the sun is hidden, it will work like any other battery just minus the eco-friendly charging while being used.
Just my piece to add.
-Jon
Mysterypete
Tue Oct 30, 2012 6:24 am
What happens about the voltage, I.e. what is the battery voltage. Does the pi have a regulator.
Peter
Return to “For sale”
