Ancle
RP2 login problem
Tue Feb 10, 2015 4:22 am
I already installed NOOBS. When I shutdown and restart. I didn't setup user name and password. However, it requires user name and password. As attached image. What should I do? Thank you!
beta-tester
Re: RP2 login problem
Tue Feb 10, 2015 5:20 am
Ancle wrote:What should I do?
wellcome and congratulation...
you really should read the sticky threads here and/or search for similar problems, befor you ask something like this... it was asked and answered million times already. :roll:
(for example, let's start with the very first tsticky thread:
[Sticky] Pitfalls for beginners
... that's, what and why they are there for :o )
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
KLL
Tue Feb 10, 2015 5:28 am
beta-tester might mean
http://www.raspberrypi.org/forums/viewt ... 57#p681357
and he must know because he must login with password raspberrz using the "wrong" keyboard LOL
darrylpi
Fri Feb 13, 2015 9:40 pm
Hi there
I have the same problem with the B+ model.
I have just upgraded to the latest version of NOOBS. On the first time boot I managed to access the GUI, however I did not quit the GUI in the proper manner as explained in one of the "sticky notes", I just pulled out the power cable. Now on reboot I get the same screen as the preceeding post. What must be entered for the login and the subsequent password? Do I have to setup my SD card again?
Some help would be greatly appreciated
Darryl
DirkS
Fri Feb 13, 2015 9:56 pm
user pi
pw raspberry
darrylpi
Fri Feb 13, 2015 11:38 pm
Hi
Thanks for your reply
I have tried that. It does not seem to work in this case.
Cheers
darryl
BMS Doug
Fri Feb 13, 2015 11:44 pm
darrylpi wrote:Hi
Cheers
darryl
Does your keyboard work correctly and allow you to enter
pi
at the username prompt? Caps lock isn't on?
When entering the password it is also lowercase and you won't see any indication that the letters are being entered while you are putting them in:
raspberry
Doug.
