RDK
Editing the Samba Config file
Wed Aug 27, 2014 8:20 am
Folks....I'm well along the way to getting my Pi basic configuration done. I just installed SAMBA and it seems to be working, ie I can see the USB key share I set up.
What I would like to do is create a cleaned up copy of the smb.conf file. It has lots of comments (#'s and ;'s) which make reading it and debugging painful. I found this script on the web:
grep -ve ^# -ve ‘^;’ -ve ^$ smb.confcopy> smb.confclean
but when I run it in super user mode, the command does not finish, that is it does return to the normal prompt even after 10+ minutes. CTL-c gets me back to the prompt.
What am I doing wrong? OS is RASPBIAN .
Thanks...RDK
RaTTuS
Re: Editing the Samba Config file
Wed Aug 27, 2014 8:41 am
are you running sudo blah or
are you doing
sudo sh
then running the command
the second will work the first will not - the redirection will not happen as you think it will
Covfefe
Richard-TX
Wed Aug 27, 2014 9:01 am
try this
cat smb.conf | grep -ve ^# -ve \.^\;\. -ve ^$ > outfile
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
jojopi
Wed Aug 27, 2014 10:55 am
RDK wrote:grep -ve ^# -ve ‘^;’ -ve ^$ smb.confcopy> smb.confclean
In the recipe that you found, there were obviously supposed to be ASCII single quotes around ^; to protect the semicolon from the shell. Something along the way has converted them into Unicode left- and right- single quotes, which no longer serve the purpose. So you have two commands separated by semicolon:
grep -ve ^# -ve ‘^;
The first grep is reading from standard input, so it waits for you to press Ctrl+D or Ctrl+C. The second "command" is nonsense.
With the correct quotes (and running in a root shell as RaTTuS explains) the command should work (though it is redundant to give the -v option three times).
Richard-TX wrote:cat smb.conf | grep -ve ^# -ve \.^\;\. -ve ^$ > outfile
You have quoted the semicolon adequately, but what are the \. for? The beginning of line (^) cannot match after ., so your version does not remove ; comments.
RDK
Wed Aug 27, 2014 11:12 am
Folks....Thanks, I think I understand the comments. The string posed by Richard-TX worked good enough for me. It did not eliminate the ; lines nor the blank lines, but did get rid of the # line comments. I can live with this reduction.
Perhaps later I will try the other suggestions and try to really understand what they are doing.
Again, thanks....RDK
tekim
Sat Aug 30, 2014 1:42 pm
Greetings,
Does the "testparm" command not achieve a similar result?
testparm > smbclean.conf
or maybe
testparm -v > smbclean.conf
for all the default setting included.
Cheers,
Return to “Beginners”
