adih2001
Compile help
Tue Jul 15, 2014 6:12 pm
Hello!
I am a small kitty i don't know how to compile this file: https://www.dropbox.com/s/f5qa8r7r3jynv ... 0.0.tar.gz
If you do know pls compile it for me! (compile it for raspberry pi)
Thx! Kitty.
Re: Compile help
Tue Jul 15, 2014 7:20 pm
cd /tmp
mv /home/dougie/pom*.*z . # move the file you've downloaded to the /tmp directory
tar xavf pom1-1.0.0.tar.gz
cd pom1*
./configure
make
sudo make install
pom1
This is a doctor free zone.
adih2001
Re: Compile help
Wed Jul 16, 2014 3:17 am
It dosen't work.. read down
adih2001
Re: Compile help
Wed Jul 16, 2014 4:20 am
It dosent work... i get some errors: (here is all i did)
pi@PiDesktop ~ $ cd /tmp
pi@PiDesktop /tmp $ mv /home/pi/pom1-1.0.0.tar.gz /tmp
pi@PiDesktop /tmp $ tar xavf pom1-1.0.0.tar.gz
pom1-1.0.0/
pom1-1.0.0/NEWS
pom1-1.0.0/configure
pom1-1.0.0/src/
pom1-1.0.0/src/pom1.in
pom1-1.0.0/src/screen.h
pom1-1.0.0/src/roms/
pom1-1.0.0/src/roms/charmap.rom
pom1-1.0.0/src/roms/basic.rom
pom1-1.0.0/src/roms/Makefile.am
pom1-1.0.0/src/roms/monitor.rom
pom1-1.0.0/src/roms/Makefile.in
pom1-1.0.0/src/m6502.c
pom1-1.0.0/src/keyboard.c
pom1-1.0.0/src/configuration.h
pom1-1.0.0/src/configuration.c
pom1-1.0.0/src/m6502.h
pom1-1.0.0/src/pia6820.h
pom1-1.0.0/src/pom1.desktop.in
pom1-1.0.0/src/keyboard.h
pom1-1.0.0/src/pom1.png
pom1-1.0.0/src/options.c
pom1-1.0.0/src/main.c
pom1-1.0.0/src/screen.c
pom1-1.0.0/src/Makefile.am
pom1-1.0.0/src/options.h
pom1-1.0.0/src/pia6820.c
pom1-1.0.0/src/memory.h
pom1-1.0.0/src/memory.c
pom1-1.0.0/src/Makefile.in
pom1-1.0.0/INSTALL
pom1-1.0.0/aclocal.m4
pom1-1.0.0/config.h.in
pom1-1.0.0/ChangeLog
pom1-1.0.0/depcomp
pom1-1.0.0/configure.ac
pom1-1.0.0/install-sh
pom1-1.0.0/Makefile.am
pom1-1.0.0/COPYING
pom1-1.0.0/README
pom1-1.0.0/AUTHORS
pom1-1.0.0/missing
pom1-1.0.0/Makefile.in
pi@PiDesktop /tmp $ cd /pom1-1.0.0
bash: cd: /pom1-1.0.0: No such file or directory
pi@PiDesktop /tmp $ cd pom1-1.0.0
pi@PiDesktop /tmp/pom1-1.0.0 $ ./configure
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for GNU libc compatible malloc... yes
checking for atexit... yes
checking for memset... yes
checking for mkdir... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strrchr... yes
checking for sdl-config... no
checking for SDL - version >= 1.1.3... no
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/pom1.desktop
config.status: creating src/roms/Makefile
config.status: creating config.h
config.status: executing depfiles commands
pi@PiDesktop /tmp/pom1-1.0.0 $ make
make all-recursive
make[1]: Entering directory `/tmp/pom1-1.0.0'
Making all in src
make[2]: Entering directory `/tmp/pom1-1.0.0/src'
Making all in roms
make[3]: Entering directory `/tmp/pom1-1.0.0/src/roms'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/tmp/pom1-1.0.0/src/roms'
make[3]: Entering directory `/tmp/pom1-1.0.0/src'
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT configuration.o -MD -MP -MF .deps/configuration.Tpo -c -o configuration.o configuration.c
mv -f .deps/configuration.Tpo .deps/configuration.Po
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT keyboard.o -MD -MP -MF .deps/keyboard.Tpo -c -o keyboard.o keyboard.c
keyboard.c:19:17: fatal error: SDL.h: No such file or directory
compilation terminated.
make[3]: *** [keyboard.o] Error 1
make[3]: Leaving directory `/tmp/pom1-1.0.0/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/tmp/pom1-1.0.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/pom1-1.0.0'
make: *** [all] Error 2
pi@PiDesktop /tmp/pom1-1.0.0 $ sudo make install
Making install in src
make[1]: Entering directory `/tmp/pom1-1.0.0/src'
Making install in roms
make[2]: Entering directory `/tmp/pom1-1.0.0/src/roms'
make[3]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/share/pom1/roms" || /bin/mkdir -p "/usr/local/share/pom1/roms"
/usr/bin/install -c -m 644 basic.rom charmap.rom monitor.rom '/usr/local/share/pom1/roms'
make[2]: Leaving directory `/tmp/pom1-1.0.0/src/roms'
make[2]: *** [keyboard.o] Error 1
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/tmp/pom1-1.0.0/src'
make: *** [install-recursive] Error 1
pi@PiDesktop /tmp/pom1-1.0.0 $ pom1
bash: pom1: command not found
AndyD
Re: Compile help
Wed Jul 16, 2014 4:23 am
You will need to install the SDL development package.
sudo apt-get install libsdl1.2-dev
Then try again from make
Re: Compile help
Wed Jul 16, 2014 4:24 am
Then try again.
adih2001
Re: Compile help
Wed Jul 16, 2014 7:41 am
Thx for help! My cat will be happy! :)
