Re: Using windows software
Tue Jun 24, 2014 10:54 pm
sudo apt-get install exim4 exim4-base exim4-config exim4-daemon-light heirloom-mailx
or
sudo apt-get install postfix
Pick your poison.
This is a doctor free zone.
piff
Wed Jun 25, 2014 9:55 am
hi again,
I found this script for python
#!/usr/bin/python
# Import smtplib for the actual sending function
import smtplib
# For guessing MIME type
import mimetypes
# Import the email modules we'll need
import email
import email.mime.application
#Import sys to deal with command line arguments
import sys
# Create a text/plain message
msg = email.mime.Multipart.MIMEMultipart()
msg['Subject'] = 'subject_you_prefer'
msg['From'] = 'senders_mail@gmail.com'
msg['To'] = 'receivers_mail@gmail.com'
# The main body is just another attachment
body = email.mime.Text.MIMEText("""Here you can write as many things as you want!""")
msg.attach(body)
# PDF attachment block code
directory=sys.argv[1]
# Split de directory into fields separated by / to substract filename
spl_dir=directory.split('/')
# We attach the name of the file to filename by taking the last
# position of the fragmented string, which is, indeed, the name
# of the file we've selected
filename=spl_dir[len(spl_dir)-1]
# We'll do the same but this time to extract the file format (pdf, epub, docx...)
spl_type=directory.split('.')
type=spl_type[len(spl_type)-1]
fp=open(directory,'rb')
att = email.mime.application.MIMEApplication(fp.read(),_subtype=type)
fp.close()
att.add_header('Content-Disposition','attachment',filename=filename)
msg.attach(att)
# send via Gmail server
# NOTE: my ISP, Centurylink, seems to be automatically rewriting
# port 25 packets to be port 587 and it is trashing port 587 packets.
# So, I use the default port 25, but I authenticate.
s = smtplib.SMTP('smtp.gmail.com:587')
s.starttls()
s.login('senders_mail@gmail.com','the_password_of_the_senders_mail')
s.sendmail('receivers_mail@gmail.com',['receivers_mail@gmail.com'], msg.as_string())
s.quit()
i am runing it using IDLE 3 and i get this error :
AttributeError: 'module' object has no attribute 'Multipart'
?! how can i correct it?
mimi123
Wed Jun 25, 2014 5:25 pm
I tested it last time on Python 2.5 so use IDLE 2 not 3.
elatllat
Fri Oct 03, 2014 3:40 am
DougieLawson wrote:Use this code...
That is a lot of code compared to say this:
curl myip.dnsdynamic.org
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
