rasp14
Question for TightVNCServer on Raspbian
Sun Jun 22, 2014 3:33 pm
Hi All,
I've just bought a Model B board few days ago and i have successfully installed Raspbian and booted it.
Just installed TightVNCServer and followed this guide http://elinux.org/RPi_VNC_Server for setting up autostart service. Everything was running ok.
I just have one question though. Why did i have to changed the command from "vncserver :0" to "vncserver :1" in order to make the program work?
I get this error message if i use the command "vncserver :0",
Warning: raspberrypi:0 is taken because of /tmp/.X0-lock
Remove this file if there is no X server raspberrypi:0
A VNC server is already running as :0
I tried to kill every tightvnc process by using "vncserver -kill :0" or "vncserver -kill :1" and run the command "vncserver :0" again and i got the same error.
I kind of loss here. Is not like the vncserver is not working. I just want to understand why i cannot start the program using ":0".
I hope someone could share with me what is actually wrong here.
Thanks in advance.
Regards.
rasp14
Re: Question for TightVNCServer on Raspbian
Wed Jun 25, 2014 3:23 am
I do some digging a i just found out that i cannot start tightvnc server at ":0" due to Xorg already taken that spot. I config-ed my Raspberry Pi to auto login to desktop during boot. Thanks for reading anyway. ;)
Cancelor
Wed Jun 25, 2014 6:43 am
I have the same but what I really want is to see the same desktop on my laptop as on my TV (RPi) ... do you know how I can do that?
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
simplesi
Wed Jun 25, 2014 6:51 am
Cancelor wrote:I have the same but what I really want is to see the same desktop on my laptop as on my TV (RPi) ... do you know how I can do that?
Use x11vnc instead of tightserver
http://cymplecy.wordpress.com/2014/02/0 ... ll-x11vnc/
then what you see remotely IS the normal desktop :)
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
Cancelor
Wed Jun 25, 2014 6:57 am
cool, thnx 8-)
