Preator
Powering with USB hub
Sat Jun 21, 2014 11:51 am
I want to add a powered USB hub for my Pi, and power it with the hub. I was thinking of this hub.
Do I have to add a USB > Micro USB cable to power it?
Re: Powering with USB hub
Sat Jun 21, 2014 2:27 pm
Yes & Yes
D-Link D-Link 7 Port USB Hub DUB-H7/B USB 2.0 7-Port 2.4 A Verified [Power USB slots can be used to power Raspberry Pi.
http://elinux.org/RPi_Powered_USB_Hubs
Retired disgracefully.....
mahjongg
Sat Jun 21, 2014 4:19 pm
I suppose it isn't "back powering" then?
Preator
Sat Jun 21, 2014 10:31 pm
It is not possible to power it only by connecting it to the USB port right?
FLYFISH TECHNOLOGIES
Sun Jun 22, 2014 1:42 am
HI,
Preator wrote:It is not possible to power it only by connecting it to the USB port right?
Use its micro USB connector for supplying it. Otherwise, you bypass internal protection circuit.
Best wishes, Ivan Zilic,
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
