I am a new user. I have a model b and have download and installed the operating system as described in this forum. I want to not have the screen automatically go to a blank screen after 10 minutes.
The system boots up in command line mode and I then log in and use the command Startx to bring up the GUI.
I have down loaded and installed Libreoffice and am running impress to display a Powerpoint presentation.
I have also down loaded and installed x11-xserver-utils
The impress is set to run the presentation in a continuous loop, forever.
I found a program called no_blank.sh on this forum and have it loaded also and have it set to manually execute. I have executed it from the command line before starting the GUI and from a window inside the GUI. In both cases, the screen still blanks after 10 minutes.
So, what am I doing wrong?
My desire is to have the screen stay active until I terminate the program.
Thanks.
Jim
