SchumyAlex
Raspi Cam + Webiopi
Fri May 09, 2014 7:36 pm
Hello there, i am a beginner in raspberry pi and i folowed this tutorial tu build a rc car with web control and camera streaming.(http://www.themagpi.com/issue/issue-10/ ... am-part-2/) This tutorial it's about how to use a usb camera, what modification should i make to stream from the dedicated raspberry camera? I want to use this camera, because it's faster and with a high quality image.
abroun
Re: Raspi Cam + Webiopi
Sat May 17, 2014 12:56 pm
Hi there,
I've put together a small program call raspberry_pi_camera_streamer, for a robot project, which should do what you want. It uses a modified version of the http server code from mjpg-streamer used in that tutorial so once you've built it, and start it running, it should work with the rest of the tutorial. The only slight issue is that by default it serves on port 8080 so you'd need to change the line in your HTML file to
<img src="http://Pi_IP:8080/?action=stream">
The bitbucket repository gives instructions for building and running the program, but let me know if you have any problems.
Regards
Alan
grinsepeter
Wed Feb 24, 2016 12:12 am
hey alan,
thanks a lot for that camera streamer. it helped me a lot.
is there a way to execute the start of the streamer via a python script. and also to turn it off?
i want to add 2 buttons to my WebIOPi to tun the camera on and off.
thanks a lot.
ben
Return to “Beginners”
