valver
Stepper motor
Fri Apr 18, 2014 6:25 pm
I bought this stepper motor : https://www.dropbox.com/s/x7sdps4dksxp3 ... 4-3008.pdf
And looking at the forum meeting different solutions to control:
-DRV8825
-Allegro A4988
-SLA7062/67
Which recommend to me? What is the easiest to implement? And the cheapest? Why this choise ?
Thanks in advance.
valver
Re: Stepper motor
Sat Apr 19, 2014 8:52 pm
Up
FLYFISH TECHNOLOGIES
Re: Stepper motor
Sat Apr 19, 2014 9:19 pm
valver wrote:-DRV8825
Not ok. (Output current limit).
valver wrote:-Allegro A4988
valver wrote:-SLA7062/67
SLA7062 conditionally suitable (not recommended for new designs):
- On upper limit for unipolar driving.
- Not suitable for bipolar driving.
valver wrote:What is the easiest to implement?
This always depends on current skills of the person involved...
valver wrote:And the cheapest?
http://www.google.com
Best wishes, Ivan Zilic.
Running out of GPIO pins and/or need to read analog values?
Solution: http://www.flyfish-tech.com/FF32
valver
Re: Stepper motor
Sun Apr 20, 2014 5:00 pm
Thanks for your answer.
-DRV8825 13.95$
Maximum current per phase: 2.2 A*
*With sufficient additional cooling.
This meets the current specifications with heatsinks
Like this?
-Allegro A4988 9.95$
Maximum current per phase: 2 A*
-SLA7062/67: Discarded
If none of the above? You recommend any?
Thanks in advance
Re: Stepper motor
Sun Apr 20, 2014 6:18 pm
valver wrote:This meets the current specifications with heatsinks
Like this?
... in case of proper dimensions... if its dimensions are 1cm by 1cm, then it's definitely not proper.
valver wrote:You recommend any?
You need to make a decision first in which mode you'd like to control your motors (bipolar, unipolar).
P.S. And... not to forget, .... this is RasPi forum...
