raspfly
Tab HDMI input
Thu Apr 17, 2014 12:27 am
Is it possible to attach a Raspberry Pi to any of those Tabs with a HDMI port ?
How can we make out if any devise having an HDMI port is programmed for data input or output ?
A TV takes input but a Tab / Mp4 player might be only for output.
Tarcas
Re: Tab HDMI input
Thu Apr 17, 2014 1:04 am
No device on the market, as far as I know, has both input and output on the same port. If it's used for output, it can't be used for input and vice versa.
raspfly
Re: Tab HDMI input
Thu Apr 17, 2014 2:56 am
Is there any way to make out what the HDMI port in any device is made for ? Input or Output ?
TV is a display device but it is HDMI port receives input but a Tab or MP4 player also has a display but mostly their HDMI port is made for output.
Tarcas
Re: Tab HDMI input
Thu Apr 17, 2014 3:29 am
raspfly wrote:Is there any way to make out what the HDMI port in any device is made for ? Input or Output ?
It sounds like you answered your own question. In a display device such as a TV or monitor, the HDMI port is for input. In a source device, be it a laptop, tablet, phone, Blu-ray player, Raspberry Pi or whatever, it will be output. If you're asking whether there's a marking or a difference in the physical connector, I don't think that there is. The Wikipedia page on HDMI may have more details though, as may hdmi.org
raspfly
Re: Tab HDMI input
Thu Apr 17, 2014 6:41 am
So does it means there is no way we can use the display of a tab or a mp4 player (through its hdmi) as a display for Raspberry Pi ?
ghans
Re: Tab HDMI input
Thu Apr 17, 2014 7:12 am
If the Tablet works , install a remote desktop client or
a VNC client and the matching server on the Pi.
Simple , and good enough for most cases.
Searching for a way to connect the display directly will
only end in frustration and unnecessary monetary expenses.
If you want to go down that route , try to get the LCD panel
out of the tablet and then ping one of the many sellers
of HDMI driver boards on i.e. eBay .
ghans
