tumblebomb
How to shutdown the rpi
Fri Jun 01, 2012 7:51 pm
Hi I just setup my Pi tonight (debian install). Created my self a different user account as in the guide and used visudo to give it sudo control, did some python coding. All going well. I come to finish my session and considered just pullling out power cable but thought I should do it properly.
I tried the power symbol at bottom and selected shutdown - it flashes up a window asking for admin passwd but went away too quickly to do anything. I logged out of LXDE and tried shutdown and halt from there which didn't work. It said 'must be supervisor'. I used sudo su and halt -l from there which worked fine.
Anything I'm doing wrong or is something mis-configured?
tumblebomb
Re: How to shutdown the rpi
Sat Jun 02, 2012 10:41 am
well I found the issue is the same as the other debian issue of programs not accepting password on the wiki. fixed now.
bredman
Sat Jun 02, 2012 11:17 am
To help others with the same problem, the fix is here
http://elinux.org/R-Pi_Troubleshooting# ... y_password
soslug
Contact: Website Yahoo Messenger
Sat Jun 02, 2012 11:22 am
Should be possible to
a) sudo halt
add your own password when asked
b) sudo shutdown -h now
Shutting down with the -r means reboot instead of -h
IPFreely, to weed the network demons that dwell in them their Windows!
redcatster
Sat Jun 02, 2012 11:49 am
i just type
sudo poweroff
BlaineThePilot
Sat Jun 02, 2012 5:20 pm
or you could try
sudo shutdown -h -t sec now
Return to “Beginners”
