adih2001
Running a command on startup
Fri Mar 14, 2014 4:58 pm
Hello! I wanna make a project and i wanna to run a command
yt
when raspberry pi starts up. How i can make that? I will be soo happy if you guys can tell me :). Thanks!
DeeJay
Re: Running a command on startup
Fri Mar 14, 2014 5:42 pm
Giving you a precise answer is not possible without knowing which Operating System you are running.
Assuming it's Raspbian, try a Google search for raspbian run command on startup - that will give you an idea of the number of times this question has already been dealt with.
The search hit labelled "Raspberry Pi web server - Run a script on start up" from the http://raspberrywebserver.com site, gives several alternatives, one of which might be suitable for you.
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
adih2001
Sat Mar 15, 2014 9:24 am
Sorry for not saying that!I am using raspbian.
Joe Schmoe
Sat Mar 15, 2014 11:07 am
Interestingly enough, that page gives a bunch of wrong answers, but doesn't give the right answer.
DeeJay
Sat Mar 15, 2014 5:15 pm
In which case apologies to adih2001 for misleading - I skimmed through it but didn't check in detail.
Would Joe care to point out a resource that DOES give the right answer ?
Return to “Beginners”
