Pikachu47
Midori Issue [solved]
Sat May 19, 2012 1:22 pm
Hi All.
I have a problem where attempting to run Midori results in the message "An instance of midori is already running but is not responding."
I've searched for the process and I don't think it is there, and I have a rebooted which also doesn't help.
Any ideas?
The Internet speed in other browsers has appeared to have ground to a halt since this problem occurred.
stevepdp
Re: Midori Issue
Sat May 19, 2012 1:34 pm
It might be that your midori configuration has somehow corrupted.
Try deleting the configuration directory to start from fresh, but back it up first incase you have anything important bookmarked and such ;-)
The config can be found in /home/pi/.config/midori
Pikachu47
Re: Midori Issue
Sat May 19, 2012 1:38 pm
Thanks. I'll give it a go.
grumpyoldgit
Re: Midori Issue
Sat May 19, 2012 1:39 pm
Have you tried switching it off and on again?
spennig
Re: Midori Issue
Sat May 19, 2012 2:15 pm
If there's no midori running, and the file
.config/midori/running
exists, then delete the file
The you should be able to restart midori.
Pikachu47
Re: Midori Issue
Sat May 19, 2012 4:57 pm
Hi.
Success.
I deleted the midori files from .config/midori and it works fine. I had no bookmarks or anything so didn't really care.
Thanks.
stevepdp
Re: Midori Issue
Sat May 19, 2012 5:12 pm
Pleased to hear it's working. For future reference though, spennig's solution probably would have been all you needed to delete.
tzot
Re: Midori Issue [solved]
Sat Jun 17, 2017 5:50 pm
In my case it wasn't enough; it was an issue of no session dbus running. The problem appeared after midori crashed unexpectedly.
This was the solution to my problem.
