68CGR
wlano: ERROR while getting interface flags: No such device
Wed Nov 06, 2013 8:54 pm
I receive this error, while attempting to run:
sudo ifconfig wlan0 up.
I have been through a dozen or so, articels that all talk about how easy it is to set up wireless on the rpi, but none seem to address the issue of the rpi not recognizing the fact that it has a wireless adaptor attached.
My /etc/network/interfaces file looks like this (based on steps found online) :
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
My /etc/wpa_supplicant/wpa_supplicant.conf file looks like this (again, based on steps found online) :
update_config=1
Of interest (to me, if not to anyone else) is that wpa_supplicant does not exist in /var/run/. I'm not sure if this is an issue, or if it would be created automatically/progammatically at some point, but thought it was worth mentioning.
I am running raspbian from the NOOBS v1_3_2 image
My wifi adaptor is the bluetooth/wireless dongle bta7300 from cirago
It is as if the OS is not seeing the Wifi connected to the system at all, and yet the bluetooth works fine, other than the fact that I have to use a usb keyboard to log in, before the bluetooth will connect to my bluetooth keyboard/mouse.
I'd also like to note that both the wifi and the blluetooth were configured and working until I misplaced the SD card and had to go buy a new one and start over.
SirLagz
Re: wlano: ERROR while getting interface flags: No such devi
Thu Nov 07, 2013 2:07 am
What's the output of lsusb and dmesg ?
68CGR
Thu Nov 07, 2013 1:50 pm
lsusb results:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 009: ID 0835:8502 Action Star Enterprise Co., Ltd
Bus 001 Device 010: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0835:8500 Action Star Enterprise Co., Ltd
Bus 001 Device 005: ID 0835:8501 Action Star Enterprise Co., Ltd
Bus 001 Device 006: ID 0461:4d15 Primax Electronics, Ltd Dell Optical Mouse
Bus 001 Device 007: ID 045e:00dd Microsoft Corp. Comfort Curve Keyboard 2000 V1.0
Bus 001 Device 008: ID 0835:8500 Action Star Enterprise Co., Ltd
Bus 001 Device 015: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
dmesg results:
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #538 PREEMPT Fri Aug 30 20:42:08 BST 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 1b000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c0545b54, node_mem_map c05f0000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 113792 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1632 bcm2708_fb.fbheight=1018 bcm2708.boardrev=0xe bcm2708.serial=0xd8a71b2a smsc95xx.macaddr=B8:27:EB:A7:1B:2A sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 448MB = 448MB total
[ 0.000000] Memory: 432220k/432220k available, 26532k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04ef844 (5023 kB)
[ 0.000000] .init : 0xc04f0000 - 0xc05111f0 ( 133 kB)
[ 0.000000] .data : 0xc0512000 - 0xc0546560 ( 210 kB)
[ 0.000000] .bss : 0xc0546584 - 0xc05ef738 ( 677 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000972] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060127] pid_max: default: 32768 minimum: 301
[ 0.060618] Mount-cache hash table entries: 512
[ 0.061441] Initializing cgroup subsys cpuacct
[ 0.061496] Initializing cgroup subsys devices
[ 0.061528] Initializing cgroup subsys freezer
[ 0.061557] Initializing cgroup subsys blkio
[ 0.061697] CPU: Testing write buffer coherency: ok
[ 0.062021] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.062161] Setting up static identity map for 0x3a5238 - 0x3a5294
[ 0.063641] devtmpfs: initialized
[ 0.075124] NET: Registered protocol family 16
[ 0.081586] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.082657] bcm2708.uart_clock = 0
[ 0.084022] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.084077] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.084113] mailbox: Broadcom VideoCore Mailbox driver
[ 0.084202] bcm2708_vcio: mailbox at f200b880
[ 0.084312] bcm_power: Broadcom power driver
[ 0.084350] bcm_power_open() -> 0
[ 0.084374] bcm_power_request(0, 8)
[ 0.585060] bcm_mailbox_read -> 00000080, 0
[ 0.585097] bcm_power_request -> 0
[ 0.585122] Serial: AMBA PL011 UART driver
[ 0.585244] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.916910] console [ttyAMA0] enabled
[ 0.941156] bio: create slab <bio-0> at 0
[ 0.946061] SCSI subsystem initialized
[ 0.950126] usbcore: registered new interface driver usbfs
[ 0.955716] usbcore: registered new interface driver hub
[ 0.961306] usbcore: registered new device driver usb
[ 0.967646] Switching to clocksource stc
[ 0.971938] FS-Cache: Loaded
[ 0.975093] CacheFiles: Loaded
[ 0.990035] NET: Registered protocol family 2
[ 0.995318] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.003056] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.009846] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.016446] TCP: reno registered
[ 1.019697] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.025590] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.032233] NET: Registered protocol family 1
[ 1.037104] RPC: Registered named UNIX socket transport module.
[ 1.043146] RPC: Registered udp transport module.
[ 1.047868] RPC: Registered tcp transport module.
[ 1.052613] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.059733] bcm2708_dma: DMA manager at f2007000
[ 1.064507] bcm2708_gpio: bcm2708_gpio_probe c051fdf8
[ 1.069960] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.079162] audit: initializing netlink socket (disabled)
[ 1.084764] type=2000 audit(0.940:1): initialized
[ 1.217506] VFS: Disk quotas dquot_6.5.2
[ 1.221876] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.230954] FS-Cache: Netfs 'nfs' registered for caching
[ 1.237603] NFS: Registering the id_resolver key type
[ 1.242860] Key type id_resolver registered
[ 1.247066] Key type id_legacy registered
[ 1.251416] msgmni has been set to 876
[ 1.257394] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.265220] io scheduler noop registered
[ 1.269174] io scheduler deadline registered (default)
[ 1.274501] io scheduler cfq registered
[ 1.309997] Console: switching to colour frame buffer device 204x63
[ 1.329653] kgdb: Registered I/O driver kgdboc.
[ 1.334955] vc-cma: Videocore CMA driver
[ 1.338973] vc-cma: vc_cma_base = 0x00000000
[ 1.343809] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.349309] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.363752] brd: module loaded
[ 1.372096] loop: module loaded
[ 1.375673] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
[ 1.383463] Loading iSCSI transport class v2.0-870.
[ 1.389398] usbcore: registered new interface driver smsc95xx
[ 1.395563] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.606606] Core Release: 2.80a
[ 1.609856] Setting default values for core params
[ 1.614847] Finished setting default values for core params
[ 1.825567] Using Buffer DMA mode
[ 1.828967] Periodic Transfer Interrupt Enhancement - disabled
[ 1.834931] Multiprocessor Interrupt Enhancement - disabled
[ 1.840607] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.845071] Dedicated Tx FIFOs mode
[ 1.849669] dwc_otg: Microframe scheduler enabled
[ 1.850098] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.855206] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.862648] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.868295] Init: Port Power? op_state=1
[ 1.872394] Init: Power Port (0)
[ 1.875798] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.882758] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.890114] usb usb1: Product: DWC OTG Controller
[ 1.894936] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.905017] usb usb1: SerialNumber: bcm2708_usb
[ 1.914530] hub 1-0:1.0: USB hub found
[ 1.922621] hub 1-0:1.0: 1 port detected
[ 1.931028] dwc_otg: FIQ enabled
[ 1.931043] dwc_otg: NAK holdoff enabled
[ 1.931050] dwc_otg: FIQ split fix enabled
[ 1.931069] Module dwc_common_port init
[ 1.931299] Initializing USB Mass Storage driver...
[ 1.940696] usbcore: registered new interface driver usb-storage
[ 1.950922] USB Mass Storage support registered.
[ 1.959869] usbcore: registered new interface driver libusual
[ 1.970092] mousedev: PS/2 mouse device common for all mice
[ 1.980657] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.990813] bcm2835-cpufreq: switching to governor powersave
[ 2.000724] bcm2835-cpufreq: switching to governor powersave
[ 2.010566] cpuidle: using governor ladder
[ 2.018805] cpuidle: using governor menu
[ 2.027014] sdhci: Secure Digital Host Controller Interface driver
[ 2.037305] sdhci: Copyright(c) Pierre Ossman
[ 2.045846] sdhci: Enable low-latency mode
[ 2.091958] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.104193] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.116429] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.128480] Indeed it is in host mode hprt0 = 00021501
[ 2.141496] usbcore: registered new interface driver usbhid
[ 2.156162] usbhid: USB HID core driver
[ 2.182447] TCP: cubic registered
[ 2.201769] Initializing XFRM netlink socket
[ 2.212378] NET: Registered protocol family 17
[ 2.227637] mmc0: new high speed SDHC card at address e624
[ 2.241918] Key type dns_resolver registered
[ 2.262393] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[ 2.250674] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.293466] registered taskstats version 1
[ 2.302204] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.334432] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.347055] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 2.368547] devtmpfs: mounted
[ 2.376449] Freeing init memory: 132K
[ 2.411877] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.423627] Indeed it is in host mode hprt0 = 00001101
[ 2.632409] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.644069] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.660125] hub 1-1:1.0: USB hub found
[ 2.669675] hub 1-1:1.0: 3 ports detected
[ 2.952110] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.062469] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.083340] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.102058] smsc95xx v1.0.4
[ 3.186781] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a7:1b:2a
[ 3.312139] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.436213] usb 1-1.3: New USB device found, idVendor=0835, idProduct=8500
[ 3.457142] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.491885] usb 1-1.3: Product: USB2.0 Hub
[ 3.500666] usb 1-1.3: Manufacturer: Action Star
[ 3.520509] hub 1-1.3:1.0: USB hub found
[ 3.538957] hub 1-1.3:1.0: 5 ports detected
[ 3.842347] usb 1-1.3.1: new high-speed USB device number 5 using dwc_otg
[ 3.966356] usb 1-1.3.1: New USB device found, idVendor=0835, idProduct=8501
[ 3.984615] udevd[154]: starting version 175
[ 4.001859] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.030311] usb 1-1.3.1: Product: USB HID
[ 4.051643] usb 1-1.3.1: Manufacturer: Action Star
[ 4.096997] hid-generic 0003:0835:8501.0001: hiddev0,hidraw0: USB HID v1.11 Device [Action Star USB HID] on usb-bcm2708_usb-1.3.1/input0
[ 4.232394] usb 1-1.3.3: new low-speed USB device number 6 using dwc_otg
[ 4.369634] usb 1-1.3.3: New USB device found, idVendor=0461, idProduct=4d15
[ 4.400320] usb 1-1.3.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.400333] usb 1-1.3.3: Product: USB Optical Mouse
[ 4.436099] input: USB Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/input/input0
[ 4.489993] hid-generic 0003:0461:4D15.0002: input,hidraw1: USB HID v1.11 Mouse [USB Optical Mouse] on usb-bcm2708_usb-1.3.3/input0
[ 4.622355] usb 1-1.3.4: new low-speed USB device number 7 using dwc_otg
[ 4.787664] usb 1-1.3.4: New USB device found, idVendor=045e, idProduct=00dd
[ 4.821842] usb 1-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.863678] usb 1-1.3.4: Product: Comfort Curve Keyboard 2000
[ 4.901877] usb 1-1.3.4: Manufacturer: Microsoft
[ 4.946047] input: Microsoft Comfort Curve Keyboard 2000 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4:1.0/input/input1
[ 5.002789] hid-generic 0003:045E:00DD.0003: input,hidraw2: USB HID v1.11 Keyboard [Microsoft Comfort Curve Keyboard 2000] on usb-bcm2708_usb-1.3.4/input0
[ 5.088640] input: Microsoft Comfort Curve Keyboard 2000 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4:1.1/input/input2
[ 5.151181] hid-generic 0003:045E:00DD.0004: input,hidraw3: USB HID v1.11 Device [Microsoft Comfort Curve Keyboard 2000] on usb-bcm2708_usb-1.3.4/input1
[ 5.292479] usb 1-1.3.5: new high-speed USB device number 8 using dwc_otg
[ 5.396326] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 5.436019] usb 1-1.3.5: New USB device found, idVendor=0835, idProduct=8500
[ 5.461842] usb 1-1.3.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.490571] usb 1-1.3.5: Product: USB2.0 Hub
[ 5.511835] usb 1-1.3.5: Manufacturer: Action Star
[ 5.535325] hub 1-1.3.5:1.0: USB hub found
[ 5.562551] hub 1-1.3.5:1.0: 5 ports detected
[ 5.690310] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 5.842932] Registered led device: led0
[ 5.862397] usb 1-1.3.5.1: new high-speed USB device number 9 using dwc_otg
[ 5.986836] usb 1-1.3.5.1: New USB device found, idVendor=0835, idProduct=8502
[ 6.011840] usb 1-1.3.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.041429] usb 1-1.3.5.1: Product: USB HID
[ 6.061824] usb 1-1.3.5.1: Manufacturer: Action Star
[ 6.095908] hid-generic 0003:0835:8502.0005: hiddev0,hidraw4: USB HID v1.11 Device [Action Star USB HID] on usb-bcm2708_usb-1.3.5.1/input0
[ 6.212509] usb 1-1.3.5.5: new high-speed USB device number 10 using dwc_otg
[ 6.334200] usb 1-1.3.5.5: New USB device found, idVendor=05e3, idProduct=0608
[ 6.361842] usb 1-1.3.5.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.391837] usb 1-1.3.5.5: Product: USB2.0 Hub
[ 6.412651] hub 1-1.3.5.5:1.0: USB hub found
[ 6.442348] hub 1-1.3.5.5:1.0: 4 ports detected
[ 6.742332] usb 1-1.3.5.5.2: new high-speed USB device number 11 using dwc_otg
[ 6.852329] usb 1-1.3.5.5.2: device descriptor read/64, error -71
[ 7.062372] usb 1-1.3.5.5.2: device descriptor read/64, error -71
[ 7.272470] usb 1-1.3.5.5.2: new high-speed USB device number 12 using dwc_otg
[ 7.382285] usb 1-1.3.5.5.2: device descriptor read/64, error -71
[ 7.592315] usb 1-1.3.5.5.2: device descriptor read/64, error -71
[ 7.802344] usb 1-1.3.5.5.2: new high-speed USB device number 13 using dwc_otg
[ 8.251837] usb 1-1.3.5.5.2: device not accepting address 13, error -71
[ 8.352295] usb 1-1.3.5.5.2: new high-speed USB device number 14 using dwc_otg
[ 8.801903] usb 1-1.3.5.5.2: device not accepting address 14, error -71
[ 8.826235] hub 1-1.3.5.5:1.0: unable to enumerate USB device on port 2
[ 8.912196] usb 1-1.3.5.5.4: new full-speed USB device number 15 using dwc_otg
[ 9.054782] usb 1-1.3.5.5.4: New USB device found, idVendor=0a12, idProduct=0001
[ 9.070144] usb 1-1.3.5.5.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 9.084171] usb 1-1.3.5.5.4: Product: CSR BS8510
[ 9.221919] Bluetooth: Core ver 2.16
[ 9.236193] NET: Registered protocol family 31
[ 9.246637] Bluetooth: HCI device and connection manager initialized
[ 9.259732] Bluetooth: HCI socket layer initialized
[ 9.270475] Bluetooth: L2CAP socket layer initialized
[ 9.281308] Bluetooth: SCO socket layer initialized
[ 9.300989] usbcore: registered new interface driver btusb
[ 13.090526] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 13.587682] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 23.165485] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 27.597949] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 27.597981] Bluetooth: BNEP filters: protocol multicast
[ 27.612536] Bluetooth: RFCOMM TTY layer initialized
[ 27.612588] Bluetooth: RFCOMM socket layer initialized
[ 27.612603] Bluetooth: RFCOMM ver 1.11
[ 28.575990] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 160.343900] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 160.378032] hid-generic 0005:04E8:7021.0006: unknown main item tag 0x0
[ 160.380873] input: Bluetooth Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.5/1-1.3.5.5/1-1.3.5.5.4/1-1.3.5.5.4:1.0/bluetooth/hci0/hci0:39/input3
[ 160.383582] hid-generic 0005:04E8:7021.0006: input,hidraw5: BLUETOOTH HID v1.1b Keyboard [Bluetooth Keyboard] on E0:91:53:4B:5A:BD
[ 221.163511] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
SirLagz
Thu Nov 07, 2013 1:51 pm
Is your wifi plugged into your USB hub ?
68CGR
Thu Nov 07, 2013 6:11 pm
Yes, it's a bta7300 Bluetooth/Wi-Fi single from cirago. The Bluetooth works fine.
68CGR
Thu Nov 07, 2013 6:13 pm
The dongle is plugged into a d-link powered usb hub
SirLagz
Fri Nov 08, 2013 1:44 am
Try plugging it in to the Pi itself and see if it works.
Also, make sure you plug the dongle in, and then plug the power into the Pi.
68CGR
Fri Nov 08, 2013 3:20 pm
My friend, you are a genious. and all I can say id DOH!!!
Although I am new to linux and the rpi, I have been supporting Windows for nearly 20 years and I forgot one rule that is not platform specific. Had I followed the KISS theory, I could have saved a great deal of time and frustration.
When connected directly to the Rpi, it comes up with no issue and can scan for and find SSIDs nearby.
I suspect this particular powered hub may not be the best choice. I will try another, and see how it goes.
Thanks for your help
SirLagz
Sat Nov 09, 2013 5:50 am
No problems :)
