ChadRpi
Multiple Use of SD
Tue Nov 05, 2013 9:40 pm
Wonder if anyone will answer this one.
Is it possible to use my Raspberry Pi for 2 things.
1. RetroPie
2. Motion i.e. webcam
Motion works by it outputing images from the webcam onto the local intranet. So could this run in the background when I am playing RetroPie?
elatllat
Re: Multiple Use of SD
Tue Nov 05, 2013 11:30 pm
not at the same time as botyh tasks use close to 100% resources AFAIK.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
SirLagz
Wed Nov 06, 2013 1:10 am
Only one way to find out for sure. Try it yourself !
Motion can use a large chunk of CPU. If all you're wanting is webcam streaming, I'd use ffmpeg over motion as that uses less CPU
