moreno5
Phptest file now showing
Sun Oct 20, 2013 8:23 pm
Hi Guys,
I have recently installed a new OS on my Pi and have been setting up the system with php5, apache2 and mysql. I have manage to view the "It works" page, but when adding the line of code to be able to view the PHPTEST file it does nothing and I cannot view it when trying to connect via the Pi's IP.
What am I doing wrong?
thanks
moreno5
Re: Phptest file now showing
Sun Oct 20, 2013 8:27 pm
Sorry, this is the line I am writing;
sudo sh -c 'echo "<?php phpinfo(); ?>" > /var/www/phptest.php'
lazarus78
Mon Oct 21, 2013 7:51 am
Web pages load the "index" or "default" file as the "home page", so rename your phptest.php to index.php
moreno5
Mon Oct 21, 2013 8:14 am
Ok, thanks, I will give that a try later and see if it works.
chilinski
Mon Oct 21, 2013 6:12 pm
You don't have to rename the file. phptest.php is fine. Just put it into your DocumentRoot directory and point your browser to it:
http://raspberrypi_name_or_ip/phptest.php.
If you get a blank page, it means there's a syntax error in the phptest.php file...you won't get an error message, you'll just get a blank page.
