klricks
Re: STICKY: Howto: Disable Screen Saver In Raspbian
Tue Feb 26, 2019 6:16 pm
jamesh wrote:
Tue Feb 26, 2019 3:26 pm
There is some official documentation here.
https://www.raspberrypi.org/documentati ... ensaver.md
If anyone finds that doesn't work, please indicate the problem by posting in this thread.
xscreensaver works but it is a 40MB install and adds a background process.
Simpler to do these commands (For GUI Desktop only):
xset s off
xset -dpms
To make permanent add those 2 commands to autostart
/etc/xdg/lxsession/LXDE-pi/autostart
jwilson115
Fri Mar 15, 2019 6:21 am
On the Console
If you are using the Raspberry Pi solely on the console (no desktop GUI), you need to set the console blanking. The current setting, in seconds, can be displayed using
cat /sys/module/kernel/parameters/consoleblank
Here, consoleblank is a kernel parameter. In order to be permanently set, it needs to be defined on the kernel command line.
sudo nano /boot/cmdline.txt
Add consoleblank=0 to turn screen blanking off completely, or edit it to set the number of seconds of inactivity before the console will blank. Note the kernel command line must be a single line of text.
regroers
Sat Mar 16, 2019 7:55 am
Thank you. This is very useful.
It is more fun to drive a slow car fast than to drive a fast car slow.
regroers
Thu Mar 21, 2019 5:51 am
Thanks man! This worked on me. :D
Moore253
Thu Jun 20, 2019 5:08 am
Edit the autostart file
For the standard Pi user:
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
For the root Pi user (if running the GUI with "sudo startx" for instance when running apps that access the IO pins):
sudo nano /root/.config/lxsession/LXDE-pi/autostart
If the above doesn't work, then there is not a per user file so edit the global one Tellthebell.com:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
klricks
Thu Jun 20, 2019 12:35 pm
If the above doesn't work, then there is not a per user file so edit the global one:
There is no reason to sudo startx not even for GPIO access. Doing so could result in a broken desktop.
Lewis-H
Tue Nov 12, 2019 11:57 am
Once installed, go to the Preferences option in the main desktop menu. You should find the screen saver application. Launch it and search for the option to disable it completely.
I tried this method and it worked for me. I hope this helps you!
Regards,
Lewis
hooverphonique
Fri Nov 29, 2019 1:45 pm
In Raspian 10/Buster, the only persistent thing that worked for me (besides installing xscreensaver) was editing "/etc/lightdm/lightdm.conf" and changing
[Seat:*]
#xserver-command=X
to
[Seat:*]
# set screensaver timeout=0 and disable dpms
xserver-command=X -s 0 -dpms
After rebooting, you can use
xset -display ":0" q
to query whether your changes were applied.
eemanshahid75
Mon Dec 16, 2019 10:16 pm
xset s off
xset -dpms
Thanks alot for sharing this and I got my solution and my screen save got disabled in raspbian, Express HR
kacateknologi
Tue Dec 24, 2019 8:07 am
Thankyou so much for this information, it really helped for me.
i'm so sorry before, can i quote this tutorial on my site https://www.kacateknologi.com? don't worry i will add the source. Thanks
klricks
Tue Dec 24, 2019 4:48 pm
Note to all:
There is now a menu option in raspi-config to disable/enable screen blanking.
sudo raspi-config
Advanced menu A6.
