d3x0r
Re: Emulating Raspberry Pi in Windows the easy way
Sat Mar 07, 2015 2:31 am
Re TAP Init failure
1) I created it, bridged it, renamed it, had network on computer... managed to get qemu to open tap once, then I guess it didn't exit well, and had to kill 'cmd'... but removed bridge and redid it and it wouldn't work until I rebooted windows... then it was able to open tap... once; I guess maybe it got stuck because I used the X button on the window? Unsure... but
Now, I have a version of qemu that opens, recognizes the tap, it thinks it's sending and receiving packets, but I don't see them on wireshark on windows...
I tried qemu 2.2, because open vpn is also now this thing called PrivateTunnel? but it fails to recognize the tap device; although without '-net nic -net tap,ifname=TAP32' (yes the tap is named TAP32 not the bridge...) but in stderr.txt it says it can't open it... and same in stdout.txt.
there's no tcpdump... maybe an equivalent in rasbian?
what version of openvpn should I go back to?
massimoG
Sat Dec 12, 2015 11:59 am
Thank you so much!
My only question is how much disk space does it have?
