poco
Re: Startup time
Mon Apr 30, 2012 12:11 pm
Questions to those who have a Pi under their hands and are knowledgeable in Linux.
How long does it take to boot the system? (is SD Card fast as can an SSD be?)
Can the Linux distrib, be personalized as to load very fast, hide the linux startup screen for a Logo and stop user from using anything else than a chosen app?
TIA.
K1lo
Re: Startup time
Mon Apr 30, 2012 12:27 pm
I"ve not timed it, but using the current Debian image my Pi boots in under a minute to the login prompt.
RaTTuS
Re: Startup time
Mon Apr 30, 2012 12:50 pm
and if you want to limit to a particular program you can provide an image that auto runs that with changed splash screens - no problems
Covfefe
poco
Re: Startup time
Mon Apr 30, 2012 3:45 pm
Thanks all.
I'll come back for more tech details, when I can get my hands on a Pi.
abishur
Re: Startup time
Mon Apr 30, 2012 7:48 pm
It take my pi a bit over a minute to boot, but I'm using a class 2 SD card that isn't 100% compatible.  It works and once it boot there are no i/o errors or anything, but on boot it goes through a bunch of start up jitters that unnaturally increases the standard boot time.
Dear forum: Play nice ;-)
asb
Re: Startup time
Mon Apr 30, 2012 10:52 pm
TIA.
Yes, I produced an image that boots to play a video in about 6-8 seconds.
Techmeology
Re: Startup time
Tue May 01, 2012 1:43 am
If you need to limit it to one app for security reasons, then be careful that you still do things like change the root and user passwords (defend against ctrl+alt+f1), ensure the various stuffs that allow the user to kill X are disabled, hide the Pi in a locked box, and so on.
To customize it, the simplest thing to do is to put an image (e.g: the Debian or Arch one) on your card, and make the modifications as you would on any Linux machine. If you want, you can then image customized version.
Check out cool stuff I'm doing, e.g my PIC Programmer for the Raspberry Pi: http://www.techmeology.co.uk/rpipic/
steveoreo
Re: Startup time
Fri Aug 03, 2012 12:24 am
wow, under 10sec, how can you make it? mind to detail the steps for us? with what SD card?
