MitchellK15
SD formatter
Sun Jun 16, 2013 2:49 pm
When I put in a 16 GB SDHC card, it said "error, either the drive or the card is incompatible". is there any other way of formatting the card?
MrEngman
Re: SD formatter
Sun Jun 16, 2013 3:24 pm
When you put it into what? And what program are you using to format it? Would help if you let us know.
MrEngman
malakai
Re: SD formatter
Sun Jun 16, 2013 5:20 pm
Confused as well but try a camera if you have one. Look through the menu if it doesn't auto prompt to format the card.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
MitchellK15
Re: SD formatter
Sun Jun 16, 2013 5:27 pm
when i put it into a dell latitude sd card reader. the program i was using to format is the one in the quick start guide.
malakai
Re: SD formatter
Sun Jun 16, 2013 5:52 pm
If it's the first time using the card reader in the laptop you might want to check their website for updated drivers typically with stock image drivers they can have issues. Since your machine can't see the card properly assuming you can't see it in My Computer I would try that if you can see it in My Computer but the SD Formatter software gives the error let us know.
FTrevorGowen
Re: SD formatter
Sun Jun 16, 2013 6:04 pm
MitchellK15 wrote:when i put it into a dell latitude sd card reader. the program i was using to format is the one in the quick start guide.
It could be that the dell's SD card slot is not SDHC compatible (esp. for writing). I've always used an external, "USB-stick-like", SDHC card reader/writer** since my ~3 year old netbook's slot is not marked "SDHC".
Trev.
** That labelled "D" in this "motley collection": http://www.cpmspectrepi.webspace.virgin ... aders.html
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
broo0ose
Re: SD formatter
Sun Jun 16, 2013 7:35 pm
I also have a Latitude (E6410) and I have the same experience.
It works fine when I use a little stick USB card reader.
