Tom Lewis
DDclient
Sat May 18, 2013 4:00 pm
Hello, Im having trouble with DDCleint and updating a sub-domain from namecheap dynamic DNS.
This is my current DDClient config
# Configuration file for ddclient generated by debconf
# /etc/ddclient.conf
protocol=namecheap
#use=if, if=eth0
use=web, web=checkip.dyndns.com/, web-skip='IP Address'
server=pi.mydomain.co.uk
login=mydomain.co.uk
password='bbbbbbbbbbbbbbbbbbbbbbbbbbbb '
pi.mydomain.co.uk
When I run
sudo ddclient
I get this response:
pi@raspberrypi:~$ sudo ddclient
FAILED:   updating pi.mydomain.co.uk: unexpected line (&ip=EXTERNAL_IP HTTP/1.0 404 Not Found
FAILED:    Server:
FAILED:    Date: Sat, 18 May 2013 15:53:14 GMT
FAILED:    Content-Type: text/html
FAILED:    Connection: close
FAILED:
FAILED:    <HTML>
FAILED:    <HEAD><TITLE>404 Not Found</TITLE></HEAD>
FAILED:    <BODY BGCOLOR="#cc9999" TEXT="#000000" LINK="#2020ff" VLINK="#4040cc">
FAILED:    <H4>404 Not Found</H4>
FAILED:    File not found.
FAILED:    </BODY>
FAILED:    </HTML>
FAILED:    )
pluggy
Re: DDclient
Sat May 18, 2013 4:05 pm
This is mine using dyndns. It may yield some clues :
protocol=dyndns2
use=web, web=checkip.dyndns.com, web-skip='IP Address'
server=members.dyndns.org
login=pluggy
password='none of yourbusiness'
pluggy.is-a-geek.com
or
http://www.namecheap.com/support/knowle ... e-ddclient
