nemo096
No sound over HDMI at all
Fri May 03, 2013 7:35 pm
I got my raspberry pi at christmas and have been happy with it - until I needed to use the sound...
I was not able to get sound working on the wheezy image so I got XBMC and the sound worked fine - came through HDMI without needing to change any settings
(back to wheezy) I installed alsa utils
sudo apt-get install alsa-utils
as Google told me to and did
sudo modprobe snd_bcm2835
to initialise the driver then tried to get it to play a sound from scratch (quickest sound file I could find) and no luck
Edited /boot/config.txt/ and forced the output through HDMI and i have gotten video fine but still cannot get audio
Anyone shed any light on why I can't get audio?
P.S I am using the pi as the brain for my AI which uses text to speech to reply to my speech commands via bluetooth mic (gioteck ex-01) and I need it to have audio to play music (big iron man enthusiast so making an iron man suit and would like J.A.R.V.I.S to go with it)
Any suggestions to the audio problem?
breaker
Re: No sound over HDMI at all
Tue May 07, 2013 2:00 am
The fix depends a bit on your Raspbian version (with the firmware I believe)
The troubleshooting wiki is good, and check this discussion:
http://www.raspberrypi.org/phpBB3/viewt ... io#p344209
