elwolv
persistent Wrong Hash value
Wed Apr 24, 2013 3:32 pm
the listed has value for download of Wheezy Raspbian
SHA-1 Checksum: b4375dc9d140e6e48e0406f96dead3601fac6c81
while the tested value using the downloaded HSA program
3613d5c1c29e9c1f17e274dfe9444bf8b9b3682
on several down load appears with the same results:
does the value on the web site not correct?
the date on wheezy 2013-02-09
lavers
Re: persistent Wrong Hash value
Wed Apr 24, 2013 3:54 pm
Are you checking the checksum of the .zip file you downloaded, or of the unzipped contents? I believe the checksum is for the .zip file.
Wed Apr 24, 2013 4:08 pm
The "3613d5c1c29e9c1f17e274dfe9444bf8b9b3682" value is very similar to the value I get from checking an unzipped image. So close, in fact, that I could quite believe that the above sum had been typed by hand with typos, rather than copy/paste.
Compare the two...
3623d5c1c529e9c1f17e274dfe9444bf8b9b3682
Apart from the fact the reported one is the wrong length... just a bit too close to be a co-incidence. I'd say the OP has a correctly downloaded file.
elwolv
Thu Apr 25, 2013 7:44 am
thank you all
correct, not zip file, but unzipped file
zip file give the correct Hash
the has was typed by hand missing a letter
