Playing music using MOC
Posted: Sun Apr 07, 2013 6:59 pm
by JizzaDaMan
I previously started a thread with the problem of playing music off a cd player, but I gave up on that, so I put the music on a USB stick and then copied them to the SD card and I am now playing them!!!
Unfortunately the music takes up rather a large amount of memory; about 0.6GB (not yet a problem, but I would like to not have to worry about it, especially when I want to add more).
Ultimately I would like to be able to simply put the music on a memory stick and play it directly from that, so how can I do it? (MOC currently doesn't recognise the memory stick, hence the need to copy the music to the SD card.
Re: Playing music using MOC
Posted: Sun Apr 07, 2013 8:04 pm
by broo0ose
Is the USB drive mounted ?
Posted: Sun Apr 07, 2013 10:41 pm
by JizzaDaMan
When I inserted the stick it opened a window registering the fact that it had been recognised.
My user guide says that means it's been drive mounted automatically (I'm very new to this stuff, all I know is from the user guide :P )
Posted: Mon Apr 08, 2013 7:12 pm
by broo0ose
OK, you say it does not recognise the memory stick but you will not see it as a separate device because that is not how Linux works.
Insert the memory stick and if it has mounted it automatically have a look in the /media folder.
Posted: Mon Apr 08, 2013 7:49 pm
by azeam
JizzaDaMan wrote:I previously started a thread with the problem of playing music off a cd player, but I gave up on that, so I put the music on a USB stick and then copied them to the SD card and I am now playing them!!!
Did you change the music directory in MOC's config file? You need to update it to the directory where the USB drive is mounted, I think the config file is located at ~/.moc/config
Posted: Mon Apr 08, 2013 10:43 pm
by JizzaDaMan
That may just work, I will try it tomorrow. That is where the file is located, I've edited it several times. Do you know what the property is called?
Posted: Tue Apr 09, 2013 1:27 pm
by robinjoo1
or look at /sda1
Posted: Tue Apr 09, 2013 1:44 pm
by JizzaDaMan
I have tried looking in the /media and there is a directory called 'externaldrive' but there's nothing in there.
I also tried changing the 'MusicDir' property in the config file to 'sda1' (the name of the USB drive that I obtained from entering 'sudo fdisk -l' ) but it doesn't exist according to MOC
Posted: Tue Apr 09, 2013 2:02 pm
by azeam
JizzaDaMan wrote:I have tried looking in the /media and there is a directory called 'externaldrive' but there's nothing in there.
What's the file system of the external drive?
Posted: Tue Apr 09, 2013 4:31 pm
by JizzaDaMan
FAT32
Posted: Tue Apr 09, 2013 5:37 pm
by azeam
JizzaDaMan wrote:FAT32
Ok. To automatically mount the hard drive after boot you'll need to edit the fstab file
sudo nano /etc/fstab
Add the following line
/dev/sda1       /media/externaldrive   vfat    defaults 0 0
Close (ctrl + x) and save (y). Read the information from fstab
sudo mount -a
The drive should now appear at /media/externaldrive and it seems like you found the right place to change the directory in the MOC config file (it should be /media/externaldrive and not /dev/sda1).
Posted: Tue Apr 09, 2013 7:12 pm
by JizzaDaMan
worked perfectly, thank you so much :)
