Willfarrell5
About to order a pi, can you check my parts?
Sat Mar 30, 2013 3:24 am
Hi can you check my parts and see if they are okay for using an airplay setup? Also, do I need a powered usb hub for a keyboard and mouse? When it is all setup I won't need the hub so I don't have to worry about powering the soundcard or wifi.... I think.
Thanks!Image
TerrorByte
Re: About to order a pi, can you check my parts?
Sat Mar 30, 2013 5:15 am
Well this is coming from one new pi user to another:
I've had my RPi for about two months now:
All I needed was a simple 4-port usb hub (list of acceptable usb hubs found at: http://elinux.org/RPi_VerifiedPeripherals)
Simple mouse (wireless)
and I use a wired keyboard.
To power the pi I have an android charger (5V at 1Amp) and an HDMI cable with an 8-gig SD card.
From the looks of it, you're pretty prepared, buddy!
rolgiati
Sat Mar 30, 2013 11:31 am
Add a power supply, and you are all set.
Willfarrell5
Sat Mar 30, 2013 4:38 pm
Thanks guys, Yeah I have an hdmi cable for my pc monitor and I have a mouse and keyboard. Also I am going to be using my android charger. Thanks guys!
aaa801
Sat Mar 30, 2013 6:11 pm
Just a tip about those usb soundcards, make sure the speaker cable isnt heating up, those things have crap voltage regulation
