3xOSC
Can't boot from sd card (pics inside)
Sun Jan 27, 2013 10:08 pm
So I am using Linux Mint 13
I got an sd card that I made sure was compatible, I used a tool to format it into a Master Boot Record, then into FAT.
I use the command line and did: dd bs=4M if=~/Downloads/2012-wheezy.img of=/dev/sdb1
it writes, and it is done but when I go and put it in my unit, it doesn't work. Only the solid red light. I have followed this guide:
http://elinux.org/RPi_Easy_SD_Card_Setu ... nd_line.29
with the latest version of the .zip file and even ran the checksums.
So I pop it back into my laptop and this is what I see:
Can anyone help me out?
Re: Can't boot from sd card (pics inside)
Mon Jan 28, 2013 5:18 am
Hmm, I wasn't aware of a Mint release for the Pi.
Anyway....
Read the instructions again.
You typed:
The instructions say:
dd bs=4M if=~/2012-12-16-wheezy-raspbian.img of=/dev/sdd
You have correctly changed "sdd" to "sdb" and the name of the downloaded file, but you have erroneously added a "1" on the end.
(Don't worry, a lot of people make that mistake :) )
