bluehampster
I have an 8GB SD Card, but only getting 4GB
Wed Jan 16, 2013 12:23 pm
I have been playing around with my raspberry pi for a few days now, but I kept running into an issue when trying to install lamp. After noticing that it was saying it was out of disk space, I did df -h and got:
Filesystem Size Used Avail Use% Mounted on
rootfs 1.8G 1.5G 215M 88% /
/dev/root 1.8G 1.5G 215M 88% /
devtmpfs 220M 0 220M 0% /dev
tmpfs 44M 204K 44M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 88M 0 88M 0% /run/shm
/dev/mmcblk0p1 56M 17M 40M 30% /boot
Which adds up to exactly 4,029,780 bytes. Can anyone tell me where the remaining space is, or how to extend the volumes?
Sorry, kind of a bit new to Linux...
joan
Re: I have an 8GB SD Card, but only getting 4GB
Wed Jan 16, 2013 1:20 pm
I haven't looked closely but I think you've double counted. You are probably only seeing the 2GB partition initially used by Linux.
Which distribution are you using?
daveake
Wed Jan 16, 2013 1:26 pm
If you're using Rapbian, just run raspi-config and choose the option to use the entire SD card. See http://learn.adafruit.com/adafruits-ras ... n/overview for example.
bluehampster
Wed Jan 16, 2013 1:53 pm
I'm running raspian, but I'm not using the visual interface. I'm directly connecting it to the network, then ssh-ing in. I don't have it in front of me atm, but how can I call raspi-config over ssh, or do I have to do something complicated?
RaTTuS
Wed Jan 16, 2013 2:03 pm
sudo raspi-config
will work fine over ssh
Covfefe
efflandt
Wed Jan 16, 2013 9:55 pm
Your count is off because rootfs and /dev/root are actually the same thing. Not sure why it is listed that way because the main (/) filesystem is actually the partition /dev/mmcblk0p2. And the tmpfs devices are all in RAM. So your real total is the size of the original image 1850 MB.
Once you use raspi-config to expand your file system to fill 8 GB SD you would see something more like this for "Size" (but "Used", "Avail", and "Use%" would vary, this one had a bunch of things added):
efflandt@rpi8 ~ $ df -h
rootfs          7.3G  5.4G  1.5G  79% /
/dev/root       7.3G  5.4G  1.5G  79% /
devtmpfs        180M     0  180M   0% /dev
tmpfs            38M  612K   37M   2% /run
tmpfs            75M  136K   75M   1% /run/shm
/dev/mmcblk0p1   56M   17M   39M  31% /boot
Note: To keep formatted things in columns when posting, highlight it and click
 button
EricBrian
Mon Apr 08, 2013 3:19 pm
I saw the same thing and thought the same. And, after expanding to the whole SD, I still see it double. I wonder if it is the way that a Mac sets up the partition table. Just a thought.
