stu232
Class 4 SDHC = doesn't work
Sat Dec 29, 2012 8:40 pm
I have a spare 4Gb SDHC Class 4 card but when I use it in any of my Pi's the boot log starts to get corrupted and the OS never completes the boot.
Is this because a Class 4 card is too slow?
My main card is a 8Gb Class 6 and it boots every time no problem.
What are the recommended speeds for SD cards for use with the Pi?
stu232
Re: Class 4 SDHC = doesn't work
Sat Dec 29, 2012 8:48 pm
Also, would this card be ok for the Pi?
http://www.ebay.co.uk/itm/SAMSUNG-SD-Pl ... 35c2c6167e
Sorry for double post but I couldn't find the EDIT option.
Mobius
Sat Dec 29, 2012 9:23 pm
SD cards are hit and miss. Did you check out the verified peripherals list here:
http://elinux.org/RPi_VerifiedPeripherals
I have only tested Sandisk cards and found two different Ultra ones that work. One of them is an older Class2 so that is not your problem. I have another Sandisk plain jane card that does kind of what you are seeing.
