PieMonkey12
Write a SD card on mac without command line using only Disc
Tue Dec 25, 2012 8:28 pm
Is it possible to write a SD card on mac without command line using only Disc Utility to restore a .iso image onto the SD card ???
Chapindad
Re: Write a SD card on mac without command line using only D
Sat Dec 29, 2012 3:49 am
No, you have to use the command line but it is very easy and there are instructions in the forum on using the dd command.
cyrano
Sat Dec 29, 2012 7:20 am
PieMonkey12 wrote:Is it possible to write a SD card on mac without command line using only Disc Utility to restore a .iso image onto the SD card ???
Yes. But it's not evident. Easier:
http://alltheware.wordpress.com/2012/12 ... ard-setup/
Read the comments!
Return to “Beginners”
