iansimons
Shutting down
Tue Dec 25, 2012 8:50 am
Got into the Raspbian GUI then found that my mouse doesn't work and being an absolute beginner to this I have a question, can I just unplug the PSU ?
stevepdp
Re: Shutting down
Tue Dec 25, 2012 9:00 am
It's highly advised not to pull the plug when running Raspbian, as the filesystem may break.
What you can do however, is switch out to another TTY like so:
CTRL + ALT + F6
Note that you can use F1-F7.
Then, log in on the new TTY and issue the command:
sudo telinit 0
This will gracefully shut down the Raspberry Pi, or you can reboot it like so:
sudo reboot
Hope this helps!
iansimons
Re: Shutting down
Tue Dec 25, 2012 9:06 am
OK thanks but although the keyboard seems to be working OK how do I move the mouse pointer F! - F7 doesn't seem to do anything?
iansimons
Re: Shutting down
Tue Dec 25, 2012 9:17 am
Thanks Steve I've got there now.
Super-Nathan
Re: Shutting down
Tue Dec 25, 2012 12:47 pm
stevepdp wrote:It's highly advised not to pull the plug when running Raspbian, as the filesystem may break.
CTRL + ALT + F6
sudo telinit 0
sudo reboot
Hope this helps!
I may be wrong, but generally the virtual console under "f7" is reserved for an X-windows session. It would be better to only switch from f1-f6
echo "Something Useful" > /dev/null
