lagerbauer
No OS to choose at startup
Fri Jan 24, 2020 6:39 pm
I just got Raspberry Pi and went through the initial configuration. I did not see anywhere where I could install Lakka, LibraElec etc? Now it started Raspbian and I set it up. Do I need to reinstall NOOBS to check if I missed those other OSes or can I still add them? I can see LibraELEC in E:\os.
If I need to reinstall NOOBS to the SD which drive I need to format? There are four new drives when I plug it to my Window laptop.
Re: No OS to choose at startup
Sat Jan 25, 2020 6:04 am
PiNN is an enhanced version of NoobS and should be able to accomplish your tasks:
https://www.raspberrypi.org/forums/view ... p?t=142574
Retired disgracefully.....
