How to install makefile on Rasbian?
Posted: Wed Nov 20, 2019 4:33 pm
by alanredbull
I have a RP3 running Raspbian and RaspberryPi-B1 hat module via https://eccel.co.uk/product/raspberrypi-b1/
They provide Linux Tool, but I am so beginner about using Makefile. So the problem is, can I use Rasbian with their linux tool through the terminal? If yes, how should I do it? I have research on how to install makefile, install the cmake and try the sudo make install command, but with no sucess. Someone can guide me a bit more. That will be very helpful for a newbie here.
This is makefile blow, and I am not sure how to proceed with it. Any help is appreciated.
CC=$(CROSS_COMPILE)gcc
CFLAGS=-I. -I./RFIDB1Library -ggdb -O0
LIBRFIDB1_DIR=./RFIDB1Library
rfidb1-tool: main.o gpio.o $(LIBRFIDB1_DIR)/librfidb1.a
    $(CC) -o rfidb1-tool main.o gpio.o $(LIBRFIDB1_DIR)/librfidb1.a $(CFLAGS)
$(LIBRFIDB1_DIR)/librfidb1.a:
    make -C $(LIBRFIDB1_DIR)
clean:
    make -C $(LIBRFIDB1_DIR)/ clean
    rm -f main.o gpio.o aes.o rfidb1-tool
install:
    cp rfidb1-tool /usr/bin
prepare:
    mkdir RFIDB1Library
    cp ../../../../../Platform/Interface/GPIO/trunk/gpio.h ./
    cp ../../../../../Platform/Implementation/RaspberryPi-Linux/GPIO/trunk/gpio.c ./
Re: How to install makefile on Rasbian?
Posted: Wed Nov 20, 2019 4:44 pm
by B.Goode
I have a RP3 running Rasbian and RaspberryPi-B1 hat module via https://eccel.co.uk/product/raspberrypi-b1/
clean:
install:
prepare:
    mkdir RFIDB1Library
Q: "How to install makefile on Rasbian?"
You don't 'install' a Makefile on Raspbian, or on any other Operating System.
It is a set of directives for the make utility, to instruct that utility how to build your application from its source code.
Usually you would simply enter
make
at the shell (command line) prompt in the directory containing the Makefile.
If that option doesn't work out it is probably best to approach the developer/maintainer/distributor of the code for detailed information. They may already have provided this either on their website or in a file named INSTALL or README.
Posted: Wed Nov 20, 2019 5:02 pm
by DirkS
As @BGoode says...
Looking at the makefile you would probably have to run
make
sudo make install
in the directory with the Makefile
assuming you have all the other necessary bits downloaded and/or installed.
Posted: Wed Nov 20, 2019 5:10 pm
by alanredbull
clean:
install:
prepare:
    mkdir RFIDB1Library
make
Hi BGoode,
Thanks for answering, and correction. I have tried to look for a README file, but there is no such file from them. That is why I am so confused now. So I am hoping someone might have same issue, or already solve my confusion. Or maybe someone has more experience with this thing, can guide me by looking at makefile that they provide.
Anyway thank you for responding >D
Posted: Wed Nov 20, 2019 5:14 pm
by B.Goode
What happens if you just try what @DirkS and I have suggested?
Posted: Wed Nov 20, 2019 5:22 pm
by alanredbull
it says that no such “no such file or directory”
I have tired "cd" into that folder and "sudo make install" or "make", but it says “no such file or directory”.
I am wonder if i need to do some editing in the makefile ?
prepare:
	mkdir RFIDB1Library
it that correct? for my raspbian OS?
Posted: Wed Nov 20, 2019 5:37 pm
by B.Goode
What is the exact (case-sensitive) name of the file whose content you have posted?
If you use
ls  # <- that is 'ell' 'ess'
at the shell prompt in the relevant directory what do you find.
It is unlikely that you need adminstrative privileges simply to build the code in your own filestore.
Failing all else -
https://eccel.co.uk/contact/
Not trying to sound unhelpful, but this looks like a commercial product you have bought, and the supplier should be able to support it.
Posted: Wed Nov 20, 2019 5:57 pm
by B.Goode
Taking far more interest in this than is healthy, I have tried the download and make process. It fails, but not in the way you describe:
pi@raspberrypi:~/eccel $ wget https://eccel.co.uk/wp-content/downloads/rfidb1-tool.zip
--2019-11-20 17:53:24--  https://eccel.co.uk/wp-content/downloads/rfidb1-tool.zip
Resolving eccel.co.uk (eccel.co.uk)... 217.160.0.220, 2001:8d8:100f:f000::229
Connecting to eccel.co.uk (eccel.co.uk)|217.160.0.220|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 30892 (30K) [application/zip]
Saving to: ‘rfidb1-tool.zip’
rfidb1-tool.zip     100%[===================>]  30.17K  --.-KB/s    in 0.04s
2019-11-20 17:53:25 (693 KB/s) - ‘rfidb1-tool.zip’ saved [30892/30892]
pi@raspberrypi:~/eccel $ unzip rfidb1-tool.zip
Archive:  rfidb1-tool.zip
   creating: rfidb1-tool_v1.1/
  inflating: rfidb1-tool_v1.1/gpio.c
  inflating: rfidb1-tool_v1.1/gpio.h
  inflating: rfidb1-tool_v1.1/main.c
  inflating: rfidb1-tool_v1.1/Makefile
   creating: rfidb1-tool_v1.1/RFIDB1Library/
  inflating: rfidb1-tool_v1.1/RFIDB1Library/ccittcrc.h
  inflating: rfidb1-tool_v1.1/RFIDB1Library/Makefile
  inflating: rfidb1-tool_v1.1/RFIDB1Library/RFIDB1ClientInterface.c
  inflating: rfidb1-tool_v1.1/RFIDB1Library/RFIDB1ClientInterface.h
  inflating: rfidb1-tool_v1.1/RFIDB1Library/RFIDB1ClientProtocol.c
  inflating: rfidb1-tool_v1.1/RFIDB1Library/RFIDB1ClientProtocol.h
pi@raspberrypi:~/eccel $ cd rfidb1-tool_v1.1/
pi@raspberrypi:~/eccel/rfidb1-tool_v1.1 $ ls
gpio.c  gpio.h  main.c  Makefile  RFIDB1Library
pi@raspberrypi:~/eccel/rfidb1-tool_v1.1 $ make
gcc -I. -I./RFIDB1Library -ggdb -O0   -c -o main.o main.c
gcc -I. -I./RFIDB1Library -ggdb -O0   -c -o gpio.o gpio.c
make -C ./RFIDB1Library
make[1]: Entering directory '/home/pi/eccel/rfidb1-tool_v1.1/RFIDB1Library'
gcc -I.   -c -o RFIDB1ClientInterface.o RFIDB1ClientInterface.c
gcc -I.   -c -o RFIDB1ClientProtocol.o RFIDB1ClientProtocol.c
RFIDB1ClientProtocol.c:17:10: fatal error: mcrypt.h: No such file or directory
 #include <mcrypt.h>
compilation terminated.
make[1]: *** [<builtin>: RFIDB1ClientProtocol.o] Error 1
make[1]: Leaving directory '/home/pi/eccel/rfidb1-tool_v1.1/RFIDB1Library'
make: *** [Makefile:10: RFIDB1Library/librfidb1.a] Error 2
Posted: Wed Nov 20, 2019 6:06 pm
by B.Goode
So install that missing dependency, and all is well...
pi@raspberrypi:~/eccel/rfidb1-tool_v1.1 $ sudo apt install libmcrypt-dev -y
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  libmcrypt4
Suggested packages:
  mcrypt
  libmcrypt-dev libmcrypt4
0 upgraded, 2 newly installed, 0 to remove and 60 not upgraded.
Need to get 152 kB of archives.
After this operation, 485 kB of additional disk space will be used.
Get:1 http://archive-bm.raspbian.org/raspbian buster/main armhf libmcrypt4 armhf 2.5.8-3.4 [64.2 kB]
Get:2 http://archive-bm.raspbian.org/raspbian buster/main armhf libmcrypt-dev armhf 2.5.8-3.4 [87.4 kB]
Fetched 152 kB in 1s (175 kB/s)
Selecting previously unselected package libmcrypt4.
(Reading database ... 93867 files and directories currently installed.)
Preparing to unpack .../libmcrypt4_2.5.8-3.4_armhf.deb ...
Unpacking libmcrypt4 (2.5.8-3.4) ...
Selecting previously unselected package libmcrypt-dev.
Preparing to unpack .../libmcrypt-dev_2.5.8-3.4_armhf.deb ...
Unpacking libmcrypt-dev (2.5.8-3.4) ...
Setting up libmcrypt4 (2.5.8-3.4) ...
Setting up libmcrypt-dev (2.5.8-3.4) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
ar rcs librfidb1.a RFIDB1ClientInterface.o RFIDB1ClientProtocol.o
gcc -o rfidb1-tool main.o gpio.o ./RFIDB1Library/librfidb1.a -I. -I./RFIDB1Library -ggdb -O0
So the build process completes, and there is an executable rfidb1-tool, not shippped with the source, newly created -
pi@raspberrypi:~/eccel/rfidb1-tool_v1.1 $ ls -al
total 348
drwxr-xr-x 3 pi pi   4096 Nov 20 18:02 .
drwxr-xr-x 3 pi pi   4096 Nov 20 17:53 ..
-rw-r--r-- 1 pi pi   4563 Mar 26  2019 gpio.c
-rw-r--r-- 1 pi pi    573 Mar 26  2019 gpio.h
-rw-r--r-- 1 pi pi   7548 Nov 20 17:54 gpio.o
-rw-r--r-- 1 pi pi  87993 Mar 26  2019 main.c
-rw-r--r-- 1 pi pi 106516 Nov 20 17:54 main.o
-rw-r--r-- 1 pi pi    570 Nov 24  2017 Makefile
drwxr-xr-x 2 pi pi   4096 Nov 20 18:02 RFIDB1Library
-rwxr-xr-x 1 pi pi 115212 Nov 20 18:02 rfidb1-tool
Posted: Wed Nov 20, 2019 6:07 pm
by alanredbull
 #include <mcrypt.h>
Thanks for giving a try.
what is your error on that? missing a file?
Another question, how do you get all the operation log?
Posted: Wed Nov 20, 2019 6:09 pm
by alanredbull
  libmcrypt4
Suggested packages:
  mcrypt
total 348
It is working now :D
a big beer for you,dude.
Thanks a lot.
Posted: Sat Dec 07, 2019 8:27 pm
by stevenfitch
I came here searching for the same issues with this same board from Eccel, this appears to have answered my questions
Posted: Sat Dec 07, 2019 8:45 pm
by stevenfitch
Hi
I got as far as this topic goes to this point however:
I now have an executable "rfidb1-tool" which gives the following when run
Usage: rfidb1-tool [device path] [command] [args ...]
i'm struggling with the "device path"
i have tried all of the device names i can think of such as "serial0", "serial1", "ttyAMA0" .... have i totally not understood something here?
Unable to open UART.  Ensure it is not in use by another application
Unable to open device serial1 for RFIDB1 module!
I have the Serial of the pi configured as:
Console = no
Serial = yes
Posted: Sat Dec 07, 2019 8:59 pm
by DirkS
Under Linux you normally use the full pathname. Try e.g. /dev/serial0
Posted: Sat Dec 07, 2019 11:33 pm
by stevenfitch
That's sorted it, thank you
