fusebox
PIR Sensor Multiple Actions
Thu Oct 31, 2019 7:24 am
I am attempting to create a sensor that will play sound files one at a time after sensing movement. (PIR sensor senses movement, sound_file_1 plays, wait for a set amount of "cool down time", wait for PIR sensor to detect movement, play sound_file_2, wait for set "cool down", wait for PIR sensor to detect movement, play sound_file_3...ect)
My current code allows for one sound file to be triggered effectively, but I am not sure how to separate the playbacks.
import os
import Rpi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
pirPin=26
GPIO.setup(pirPin,GPIO.IN)
cooldown = 60
def MOTION_one(pirPin):
	print("motion 1 detected")
	os.system("aplay SOUND1.wav")
	time.sleep(cooldown)
	print("all clear")
def MOTION_two(pirPin):
	print("motion2 detected")
	os.system("aplay SOUND2.wav")
	print("all clear")
def MOTION_three(pirPin):
	print("motion3 detected")
	os.system("aplay SOUND3.wav")
	print("all clear")
print("motion sensor test")
time.sleep(2)
print("ready")
try:
	GPIO.add_event_detect(pirPin, GPIO.RISING, bouncetime=200)
	GPIO.add_event_callback(pirPin, MOTION_one)
	GPIO.add_event_callback(pirPin, MOTION_two)
	GPIO.add_event_callback(pirPin, MOTION_three)
	while1:
		time.sleep(1)
Any help is greatly appreciated
pcmanbob
Re: PIR Sensor Multiple Actions *Time Sensitive*
Thu Oct 31, 2019 10:20 am
Hi.
Try this code
import os
import time
pirPin=26
cooldown = 60
def MOTION_one():
	print("all clear")
def MOTION_two():
	print("all clear")
def MOTION_three():
	print("all clear")
time.sleep(2)
print("ready")
sound = 1
while true:
    while GPIO.input(pirPin) == 0:
            time.sleep(0.2)
    if sound == 1:
        MOTION_one()
    if sound == 2:
        MOTION_two()
    if sound == 3:
        MOTION_three()
    sound = sound + 1
    if sound == 4:
        sound = 1
untested so expect errors
Bope
Thu Oct 31, 2019 12:23 pm
I would write only one def and use the counter to build the name of the sound file. This way you can easily add of subtract sound files as needed with out having to write or delete def. Something like this:
x=1
def MOTION(x):
	sound_file = ('aplay SOUND' + x + '.wav')
	print('motion ' x ' detected')
	os.system(sound_file)
	print("all clear")
try
	while x in range [1,3]:
           		 time.sleep(0.2)
		MOTION(x)
		x = x + 1
		if x ==4:
			x=1
		time.sleep(1)
There are probably better ways to handle that counter but I am just not thinking of it right now. The syntax may not all be correct so there might be a little troubleshooting. I think this will give you a cleaner code and all you have to do is change the range of x to add or subtract sound files.
fusebox
Thu Oct 31, 2019 2:52 pm
Hi.
Try this code
import os
import time
pirPin=26
cooldown = 60
def MOTION_one():
	print("all clear")
def MOTION_two():
	print("all clear")
def MOTION_three():
	print("all clear")
time.sleep(2)
print("ready")
sound = 1
while true:
            time.sleep(0.2)
    if sound == 1:
        MOTION_one()
    if sound == 2:
        MOTION_two()
    if sound == 3:
        MOTION_three()
    sound = sound + 1
    if sound == 4:
        sound = 1
PCMAN Bob, this is exactly what my sleep-deprived brain couldn't quite get right.
It's now working perfectly. I will share working code shortly.
Thank You!
fusebox
Thu Oct 31, 2019 3:40 pm
! Working Code !
import os
import RPi.GPIO as GPIO
import time
pirPin =26
cooldown(60)
def MOTION_one():
	print("motion detected 1")
	os.system("aplay Sound1.wav")
	print("all clear")
def MOTION_two():
	print("motion detected 2")
	os.system("aplay Sound2.wav")
	print("all clear")
def MOTION_three():
	print("motion detected 3")
	os.system("aplay Sound3.wav")
	print("all clear")
print("PIR Sensor Initializing")
time.sleep(0.2)
print("Ready to Sense")
sound =1
while True:
	while GPIO.input(pirPin) == 1:
		time.sleep(0.2)
		if sound ==1:
			MOTION_one()
		if sound ==2:
			MOTION_two()
		if sound ==3:
			MOTION_three()
		sound = sound +1
		if sound ==4:
			sound = 1
Thank you to all who responded and helped make this happen so expediently!
Sean_Creatif
Fri Jan 24, 2020 9:32 pm
Can you post a photo of where you have your pins in place? I am trying to wire a pir motion sensor to a raspberry pi zero w, w/out using a breadboard.
Based on this image
I would assume I just need to replace your pin(26) with pin(7)?
I would love to know how to get it to just play one sound file too?
pcmanbob
Sat Jan 25, 2020 11:33 am
If you look at this thread https://www.raspberrypi.org/forums/view ... 2&t=262882
i have just posted connection diagram for connecting and using a PIR without a breadboard, there is also basic test code there too.
