david_1234
PI4-buster Vs. PI3-stretch
Mon Oct 28, 2019 3:29 pm
Hello ,
up until now I run my code on PI3-stretch
wanted to know if there are any changes I need to do in the setting when moving to buster ?
I want to remove the pi icons at startup,diable the black screen after 10 min , show my own logo in boot
this is what I did until now:
Sudo nano /boot/config.txt
Add this line:
disable_splash=1
Sudo nano /boot/cmdline.txt
Add this to the end of the line
logo.nologo
change the image splash.png (with my own image) in
/usr/share/plymouth/themes/pix/
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart.txt
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xset s noblank
@xset s 0
@xset -dpms
point-rpi
@chromium-browser --start-fullscreen --start-maximized /home/pi//angular-node/src/startPage.html
upload the memory to 1024 in: ---? do I still need to do this? (I'm using PI4 4G)
sudo nano /etc/dphys-swapfile
Thanks ,
****Update****
I have try to run with this setting:
I don't see the 4 pi icons at startup
I don;t see the splash.png image I have uplaoded
and it's seem that this command is not working
The browser is not open on startup
but if I run the command on the CMD - it's working and my code \webpage is running with out any problem
why?
jahboater
Re: PI4-buster Vs. PI3-stretch
Mon Oct 28, 2019 3:45 pm
No. That gave an extra 1GB of swap space providing 2GB in total of virtual memory.
You now have 4GB of real memory!
Its unlikely you will need much, if any, swap for a 4GB Pi4.
david_1234
Mon Oct 28, 2019 3:56 pm
OK , Thanks (As I thought - but wanted to be sure)
and on the other issues?
