david_1234
Help installing Netflix on PI3
Tue Oct 22, 2019 1:53 pm
Hello ,
I'm using PI3
with this version install :
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
Chromium version:
Version 72.0.3626.121 (Official Build) Built on Raspbian , running on Raspbian 9.11 (32-bit)
I'm looking for a guide that will make Netflix work with this setting
all I have found is for Chromium version 74
but I can't seem to upgrage the Chromium to this version
does someone else heve this problem ?
what can I do , and how can I fix this ?
Thanks ,
Re: Help installing Netflix on PI3
Tue Oct 22, 2019 2:22 pm
Hello ,
I'm using PI3
VERSION_ID="9"
ID=raspbian
ID_LIKE=debian
Chromium version:
Thanks ,
https://help.vivaldi.com/article/raspberry-pi/
Retired disgracefully.....
david_1234
Tue Oct 22, 2019 6:09 pm
Something is not working for me ,
this is what i did :
1. download and install Vivaldi Linux DEB ARM,
2. added the User-agent as it said
3. try to make it run in Chromuim and in the Vivaldi browsers
get the same error
why?
I have notice that it said :
AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.102 Safari/537.36
and the version of the chromuim is 72
maybe this is the problem?
also it doesn't say how to install Widevine
can you help me find a solution for this ?
it's getting very frustrated.....
Thanks ,
Tue Oct 22, 2019 6:26 pm
get the same error
why?
Thanks ,
Until Netflix do not require Secure Boot / DRM it will be frustrating, take it out on Netflix not here in this Voluntarily run Forum.
This may give you some pointers:
https://blog.vpetkov.net/2019/07/12/net ... -chromium/
If not go Googling...........
david_1234
Thu Oct 24, 2019 6:08 am
I have no problems with the GREAT people and help I get here,
it just I'm trying to make it work more then 1 month - and I didn't think it will be so hard to do...
I understadn the proboem is Netflix ,
*** I have try the link you post - this is for chromuim 74 , and pi 3 for some unknown reason won't let me update more then 72( this is the first think I have try )
I just can't believe that I am the onky one in the world that try to run Netflix on PI3 - stretch , that is all.
Thank you anyway ,
Thu Oct 24, 2019 10:05 am
Thank you anyway ,
The first response had a link to install Vivaldi Browser !!
Raspbian Stretch has been superseded, Raspbian Buster since June has been the supported Operating System.
david_1234
Sat Oct 26, 2019 7:41 am
1. I know -I install it , opened it , enter Netflix website - and got the same error. so it didn't help - I mention this .
2. so you think that if I will upgrage the PI from Stretch to Buster it might work ?
I have all kind of other programs that are running on the pi right now , will they still work?
do I need to make a fresh new installation for this ? ot there is a way to just upgrage?
Thanks ,
Sat Oct 26, 2019 8:19 am
Thanks ,
https://www.raspberrypi.org/blog/buster ... -raspbian/
