sasagr
Raspberry pi 4 and fan
Sun Oct 13, 2019 5:09 pm
Hi.
I m at my third pi device, after the pi and the pi 3 I got the pi 4 with 4GB of Ram.
I just bought this also.
https://www.amazon.co.uk/GeeekPi-Raspbe ... =8-2-fkmr2
I was reading that it is not a good idea, actually bad, to connect it to the 3V gpio pin. Maybe the 5V but not the 3V.
I was wondering if the pi4 being more powerful and getting higher power can handle this fan directly connected to the gpio without being too worried about SoC damages.
Any feedback would be much appreciated.
Imperf3kt
Re: Raspberry pi 4 and fan
Sun Oct 13, 2019 6:49 pm
The fear about using a 3v pin on the GPIO header is that it's only supposed to supply a small amount of current and a fan may draw more than it can supply.
From anecdotal evidence I've read on the forums here, it seems to work just fine, so it's up to you if you proceed.
55:55:44:44:4C
52:4C:52:42:41
davidcoton
Sun Oct 13, 2019 9:12 pm
The fan should not be connected directly to a GPIO. It is likely to draw too much current, and may produce back EMF when switched off. Either of these will damage the Pi.
The Amazon listing does not give a specification for the fan supply (neither voltage nor current). You might get away with connecting the fan to the uncontrolled 3V3 supply on the GPIO header, but I personally would not try even that. The 5V supply should be OK. I would be inclined to try a thermally controlled drive from a GPIO via a transistor to the 5V supply, but without a spec for the fan it is impossible to give proper advice.
Signature retired
W. H. Heydt
Mon Oct 14, 2019 1:24 am
Once again, I have to point out that pretty everything that mounts on a Pi grabs the first 6 pins, which includes the only 2 5v pins. The problem in this area that I'm looking at is connecting an RTC and a fan. So the fan is going to have to run of a 3.3v pin.
LTolledo
Mon Oct 14, 2019 1:44 am
not a solution for the weak-willed and/or shaky-hand types.....
Some people be like:
Imperf3kt
Mon Oct 14, 2019 5:42 am
I would consider adding some form of strain relief to that connection. Your soldering is very neat, but it'd probably ruin your day if you accidentally lifted one of those pads because the cable snagged on something.
55:55:44:44:4C
52:4C:52:42:41
boyoh
Mon Oct 14, 2019 11:14 pm
If you use the Pi as it should be used, you don’t
Need extra heat sinks or fans, Just use the Pi
Low current to switch transistors and
Opto isolators as buffer stages Such as voltage
Levelling and current amplifying from a separate
Power supply to run your project
Regards BoyOh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
Imperf3kt
Mon Oct 14, 2019 11:43 pm
Regards BoyOh
We need 1.5GHz and 4GB of RAM for that?
Maybe the first Pi has those as it's intended use, but the Pi4 has clearly been designed to be used for much more than that.
The Pi's 'intended use' now appears to be dual display advertising machines.
55:55:44:44:4C
52:4C:52:42:41
boyoh
Tue Oct 15, 2019 11:19 am
Regards BoyOh
Is it getting to the point that the Raspberry Pi
Will lose it’s Credit Card Size, The latest Pis
Are having to many components crammed on
To the PCB. This raises the point of higher temperature due to cramped components
Also making them run faster can cause higher
Temperature rise, Fast changing signals tend
To draw more current at their peak change
Regards boyoh
alphanumeric
Tue Oct 15, 2019 11:51 am
You can connect multiple devices to the +5V pins. I use a Proto Hat. I solder my RTC board right to it then add headers for anything else I want to connect. If you use a stacking header you can plug a hat in on top of the proto hat.
https://www.adafruit.com/product/2310
EDIT: One of the items being a Fan complicates things though.
