Ecofg
power on raspberry pi 4 when it gets power
Mon Sep 23, 2019 6:50 pm
I am working on a NAS raspberry pi 4 server, but one of the biggest issues is power loss. Can I make so that when the power goes back online the raspberry pi also turns on?
I thought about a UPS, but there arent any UPS's for raspberry pi 4 on aliexpress as far as I've seen.
pcmanbob
Re: power on raspberry pi 4 when it gets power
Mon Sep 23, 2019 6:59 pm
As far as I am aware if you remove the power from a pi and there is no SD card corruption , when power is reapplied the pi will boot all on it own.
If you are building a pi based NAS I assume you will be using HD's of some sort for storage, you will need to protect them from power failure as well as the pi.
why not just get a standard stand alone UPS and power the pi and any HD's from that.
Something like this for example https://www.amazon.co.uk/APC-Back-UPS-B ... 064&sr=8-3
alphanumeric
Mon Sep 23, 2019 7:01 pm
All my Raspberry Pi's boot up as soon as I plug in the power supply? If the power goes off, and then comes back on, they just boot up again. If your SD card gets corrupted when the power fails they won't recover, is that what your wondering about?
klricks
Mon Sep 23, 2019 7:10 pm
The RPi should restart if the power outage is long..... 3 or 4+ seconds, but may not restart reliably if the outage is short.
I would look into getting an AC mains UPS and run the NAS and RPi on that.
LTolledo
Tue Sep 24, 2019 3:26 am
For your setup I also recommend getting a standard PC UPS....
Some people be like:
