blueagent
can abrupt shutdowns cause OS to be corrupted?
Sun Sep 15, 2019 6:54 am
i usually just flip the switch on the power-strip to turn the pi3 off, even while its playing videos or running games.
will this cause the OS to become corrupted? or cause data corruption of my stuff on the SD-card?
thanks for letting me know!
mby
Re: can abrupt shutdowns cause OS to be corrupted?
Sun Sep 15, 2019 7:01 am
Yes; particularly SD cards with read/write-access seem to be prone to corruption caused by sudden loss of power...
See for example https://www.raspberrypi.org/forums/view ... p?t=230135 for some use cases and ideas.
RonR
Sun Sep 15, 2019 7:03 am
You're living on borrowed time. You MUST do any orderly shutdown:
sudo halt
Wait until the green LED blinks 10 times and stops before removing power.
B.Goode
Sun Sep 15, 2019 7:51 am
What is the question?
Definitely, repeatedly, without exception? No. (As you have proved.. )
Randomly, unpredictably, at the worst possible time? Yes.
Conclusion: a clean shutdown prior to removing power will improve your chances of not encountering OS or data corruption.
