SnowsongWolf
Dual HDMI Output on RPi 4
Sun Sep 15, 2019 3:13 am
Long story short, I have an RPi 4 with 2 HDMI displays. Both displays are working, however I have the same output on both. Which is to say there is only fb0 showing in /dev. How do I get individual framebuffers for each monitor? I'm running Raspbian buster lite (no desktop). My Google-fu is usually strong but I've been searching for a few hours with no luck.
SnowsongWolf
Re: Dual HDMI Output on RPi 4
Sun Sep 15, 2019 4:52 am
Nevermind, finally figured it out. I had to disable the optional driver loaded in the [rpi4] section of /boot/config.txt
PeterO
Sun Sep 15, 2019 6:20 am
That doesn't sound right. It should work twin headed "out of the box".
What exactly did you change in config.txt ?
PeterO
Sun Sep 15, 2019 8:23 pm
With the FKMS driver re-enabled (with it off you lose 3d acceleration), you get one frame buffer, but you can make it incorporate the two displays. Go to the screen configuration utility, and you will see just one display, but that is in fact one over the other. CLick and drag the display around and you will see its actually two displays, and you can then set them up as you want, including different orientations, gaps between etc.
DirkS
Sun Sep 15, 2019 8:28 pm
OP is running Lite (no desktop)...
KenT2
Mon Sep 16, 2019 6:52 am
use the xrandr command
Mon Sep 16, 2019 6:26 pm
Which is all the Screen Saver configuration tool does under the skin,
DirkS
Mon Sep 16, 2019 8:31 pm
Not installed on Lite...
It's part of the package x11-xserver-utils
Mon Sep 16, 2019 8:34 pm
TBH, if you are not using the desktop, legacy graphics mode will probably be fine, and gives you two framebuffers rather than one over two displays.
